Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: Banded Steelies Fitment Question
    Moderator Moderator Dave.'s Avatar
    Widnes - Cheshire UK
    7,411
    Default Banded Steelies Fitment Question
    Will a set of SR steels (ET49) banded to 8J Fronts and 9J rear... ,,, will they stick out of saloon arches atall or will i just get away with it?
    Nova 1.0l Project - Nova Saloon Daily Hack - Cavalier SRi Project - Nova 1.3 SR Project - Mini City Project - Digi Dash Fitting Guide
    Quote Originally Posted by Ernie at PVS08
    I mean, how did you make your car lighter? Poly-carbs, stripped out carpets, all i did was have a big poo.
    " Make Way For The Ess Ohh Vee!!! "
    Jul 2012
    Birkenhead, Merseyside
    3,317
    i would say that the 9's would stick out but 8's on the rear are usualy fine but would poke out on the front i think
    7,411
    The 9J ones are for the rear, and the 8J ones are for the front, cant find any images of any banded this wide
    23,816
    Doesn't banding change the offset quite a lot....
    7,411
    They have been outer banded Benn, so shouldn't effect the offset?
    Oct 2011
    Warton, Preston
    1,157
    Unless they are double banded equally the offset is affected.
    7,411
    Quote Originally Posted by SimonTW View Post
    I dont understand?? Can youe explain?
    Oct 2011
    Warton, Preston
    1,157
    I'll try....
    If you make the section in front of the mounting face wider, then the measurement between the centre line of the wheel and the mounting face changes causing the offset to change.
    If they are banded in front of the mounting face and behind the mounting face of the wheel the distance between the mounting face of the wheel and the centre line of the wheel remains the same meaning the offset doesn't change.
    Mar 2010
    Newcastle
    3,276
    Quote Originally Posted by Dave. View Post
    If you have a 5J wheel for example and want to make them 9J double banding means there will be 2" added on the front and 2" on the rear
    So, ET49 - 2" (50mm) = ET-1
    7,411
    Ahh now i understand! i THINK they're single banded on the faces so the offset shouldn't be effected? EG they wont touch the inner arches/shocks?
