Will a set of SR steels (ET49) banded to 8J Fronts and 9J rear...,,, will they stick out of saloon arches atall or will i just get away with it?
Nova 1.0l Project - Nova Saloon Daily Hack - Cavalier SRi Project - Nova 1.3 SR Project - Mini City Project - Digi Dash Fitting Guide![]()
" Make Way For The Ess Ohh Vee!!! "Originally Posted by Ernie at PVS08
i would say that the 9's would stick out but 8's on the rear are usualy fine but would poke out on the front i think
The 9J ones are for the rear, and the 8J ones are for the front, cant find any images of any banded this wide
Doesn't banding change the offset quite a lot....
Unless they are double banded equally the offset is affected.
I'll try....
If you make the section in front of the mounting face wider, then the measurement between the centre line of the wheel and the mounting face changes causing the offset to change.
If they are banded in front of the mounting face and behind the mounting face of the wheel the distance between the mounting face of the wheel and the centre line of the wheel remains the same meaning the offset doesn't change.
Ahh now i understand! i THINK they're single banded on the faces so the offset shouldn't be effected? EG they wont touch the inner arches/shocks?
