Cracked on with the engine work today....
Got all 4 pistons cleaned up and new rings and shells installed and put back into the block...
New GM oil pump was added as well ...
Cleaned up the pickup pipe as it was rather cruddy and reinstalled with an new o ring....
Torqued everything down and then put the sump on with some sealant as these engines don't have a sump gasket....
Next up was starting on the cylinder head , all 16 valves are rather caked with carbon...
This was an inlet valve before.....
And this is after cleaning .....
Also thought it would be rude not to get the dremmel out and polish out the ports as they seem to have a very rough casing on the inside, I have left it roughish as I understand these engines work better with the inlet rough, will give the exhaust ports a good going over ....
Need to finish off the polishing with a longer sanding bit.
Enjoy!
Joff
not the best I've seen though! BGA MLS gasket on a 106 gti... 80Nm, 90, 90, 90, 90!! I was sweating at the end
