Nice, tho i dont get all the camber.toe figures stuff, im just not cleaver enough!
As for the bushes, best way i found is cut all the way round with a hack saw down to the mettle bush on both sides then just hammer them out!
I'm not to fussed, been doing some wiring bushes and found some scabbing that i did know was hiding around the sunroof drain. So i'm gonna set about cleaning that all up, then i can seal and repaint everything.
I'll be at Billing with Migclub so make sure you come over and find me.
I dont, but am learning. Camber is easy really. Toe is abit more tricky.
Well, yeah i guess it's not really. As it's the same as setting camber up just a different angle.
I'm not sure what just happened so I'll just assume you worked it out for yourself somewhere in that and posted something along those lines![]()
I thought about it again, camber and toe are the same things, just at different angels. So both are easy to correct with a bit of measuring and some trigonometry to work out what is needed. That is the hard part.. As i dont remember being tough it at school..![]()
Benn....can i ask a massive favour. Whilst you have your beam stripped, can you measure the length of the springs on your rear shocks please.
Heres why...http://www.pngclub.com/forum/showthr...oilover-issues..
My Rebuild
Replied to your thread Pete.
Good work dude!
