Page 69 of 105 FirstFirst ... 1959676869707179 ... LastLast
Results 681 to 690 of 1050
Thread: My XE nova on throttle bodies (Project 275+bhp)
  1. #681
    Jun 2007
    cumbria
    953
    NA novas are like getting a blow job off the wife, 400 bhp let novas are like getting one from her younger sister
  2. #682
    Dec 2003
    18,397
    Quote Originally Posted by nova_stee View Post
    Meaning that the LET is risky an expensive and will end in tears!
  3. #683
    Feb 2010
    durham
    1,529
    Lol
    TBF though I be the there are modded turbo novas now then high power xe's
  4. #684
    Aug 2006
    134
    Quote Originally Posted by lee303 View Post
    hmm, not really in my eyes
    i would not want to be running it with the input shaft not fully engaged with the clutch plates, as the clutch splines will be designed to deliver that torque over the whole width of a clutch plate, so you may find it rounds the end off the shaft, or the clutch plate splines themselves could fail, which is probably the more likely as they are fairly soft in comparison to the input shaft
    why do you need a twin plate? as like you say the torque rating is ‘overkill’ a single with a decent spring rate would be plenty imo, and have room in the box
    Single plate was not reccomended by AP's technical department, but a twin plate was.
    The input shaft would only be short by 4mm or less, possibly only 2mm if Gareth removes more metal from the gearbox casing (merris style)
    AP said it will be ok as each plate has to deal with 100ish ft/lbs of torque.
    One of AP's hydraulic round face 54mm slave cylinder and thrust bearing will sort the operation of the clutch.
    Steve
  5. #685
    Feb 2010
    durham
    1,529
    Quote Originally Posted by steveboyslim View Post
    Steve
    Cheers for the info steve.
  6. #686
    Jun 2007
    ruislip
    221
    Steve
    fair enough, surprised a single wasn’t enough though, sound alike the splines would be all the way through the plates anyway at 2mm short
  7. #687
    Jun 2007
    cumbria
    953
    ha ha
  8. #688
    Jul 2002
    7,862
    if you send your gearbox down here, i will get merris to shave the 2mm off with his axe?
  9. #689
    Feb 2010
    durham
    1,529
    Quote Originally Posted by Paul View Post
    Haha cheers Paul but only if he uses a big axe
  10. #690
    Jun 2007
    ruislip
    221
    ha ha
    aimed at me?
