NA novas are like getting a blow job off the wife, 400 bhp let novas are like getting one from her younger sister
Single plate was not reccomended by AP's technical department, but a twin plate was.
The input shaft would only be short by 4mm or less, possibly only 2mm if Gareth removes more metal from the gearbox casing (merris style)
AP said it will be ok as each plate has to deal with 100ish ft/lbs of torque.
One of AP's hydraulic round face 54mm slave cylinder and thrust bearing will sort the operation of the clutch.
Steve
ha ha
if you send your gearbox down here, i will get merris to shave the 2mm off with his axe?
No aimed at scott pal
Well we decided to play nice tonight seeing as there was some sun. We made this alloy spacer to see if it would come out ok.
This was the end result.
http://i761.photobucket.com/albums/x...0/DSC03843.jpg
Not bad really as we knocked it up quickly and came out better than expected
Cheers
I got the spacer trial fitted last night and it seems to be a winner all the holes line up correctly the sits nice and the spacer doesn’t protrude the casing either inside or outside of the box so you cant even tell its there. I did some proper measuring as well seeing as I treated myself to a new vernier (B&Q tape measures aint all they used to be), I found that the input shaft does slide all the way through the collar of the rear clutch plate but only just. and I have a clearance of 0.9mm from the box to the clutch face im going to clean the box face back with the power file a touch more just to get at least 1mm's clearance.
And it leaves 45mm to fit the hydraulic bearing in place just got to do the PCD of the F20's turret mounts to see which bearing is the correct fit.
Cheers Gareth.
Lucky sod! though i would want least 2mm clearance, just encase there was for some reason any movement/wobble, not that there should, just i wouldn't want something to move slightly and it end in tears etc..
I know you mean Scott I can probs get that much with a skim off the box lol
Hello mate,
Sorry didnt reply to your pm, just been flat out at work!! Just caught up on your build.... I run a quarter master twin plate clutch and an SBD flywheel! It fit in with no issues first time, admitedly there was a very slight mark on the gearbox but later found a head of a 10mm bolt from a gaurd/cover had been rattling round in there! I have a spare ap 7.25" at home for a RS and that fowls the bolts that hold it to the flywheel! Bad times! Glad to see you got it sorted though! not far off by the look of things!
Sweet, hopefully see you there then mate! im saving pennies to get the new bits i want.... going for some internal changes rods pistons and cams so should be ready rougly the same time.
Keep up the posting mate!
Any updates mate got your gearbag fitted ok in the end?
Hi mike yeah the gearbox fits fine now mate just waiting for the AP bearing to arrive (it's on back order). As soon as that arrives its full steam ahead mate maybe another 2 Wk ends work then my mate is going freshen the painteork p on the outside.
Cheers Gareth
Hi all thought it was about time that this had an update.
Got the remote oil filter mounted a while ago.
http://i761.photobucket.com/albums/x...0/DSC04006.jpg
Easy filter change aswell.
I also started with fitting the hydraulic bearing from AP. fresh out the box
http://i761.photobucket.com/albums/x...aringfront.jpg
We trial fitted it in the box but it was catching the casing so I have to file some of the casting away
http://i761.photobucket.com/albums/x...0/DSC03999.jpg
Also cause the bearing is for a saab box fitment we could only get one of the holes lined up, so we made a plate from 1.6mm alloy plate.
http://i761.photobucket.com/albums/x...0/DSC04000.jpg
Fitted in the box
http://i761.photobucket.com/albums/x...0/DSC04002.jpg
we found the easiest way to fit the two items together first then to fix it to the box, the only real issue that i came across was on one of the bolt holes i could only fit an M5 bolt not M6 :(
http://i761.photobucket.com/albums/x...0/DSC04003.jpg
We refitted the box and found we have a success. the bearing sits away freely and the clutch doesnt catch
http://i761.photobucket.com/albums/x...0/DSC04010.jpg
http://i761.photobucket.com/albums/x...0/DSC04012.jpg
I just need to remove the box and tidy the area i have filed down, also make a slight channel cause the bolts that hold the clutch on are close to the casing.
Also get a input shaft seal to suit and it offically hyraulic clutch.
I managed to get my dash down to prey last week aswell so should be back in the new year covered in flock.
also ordered some fibreglass doors to pick up soon :)
and the pilbeam tie bar kit should be ready after xmas then its all go go go.
Thanks for looking. Gareth
Where you getting the Pilbeam tie bat kit from?
Aah same ones iam waiting on then :)
Immense
Sorry for the delays on the kits guys, I'm seeing him boxing day and with any luck the parts for the kits are being done over the Christmas holiday.
I'll be in touch with you both shortly but have a good Christmas :)
Good update btw Gareth, keep at it
No bother mate and thanks for the comment
Hi there nice nova mate were u get the head done if you don't mind my asking
absolute stunner Gareth. even better in the flesh
i seen this car a couple of weeks back the amount of work (and money) thats gone into it is insane, pic's don't do it justice mate,
Cheers gaz
