Page 403 of 410 FirstFirst ... 303353393401402403404405 ... LastLast
Results 4,021 to 4,030 of 4099
  1. #4021
    13,605
    Great info, thank you! I can see the wheel is well forward in the arch.
    With mine being rwd I don’t have shaft issues. I’ve set my engine & therefore subframe quite far back which means so does the suspension. I’d done this “assuming” I could centralise the wheel again with castor.
    Duh, RWD project, of course no shaft issues! Haha. I guess the concern is you end up with too much caster to put the wheel in the middle of the arch.
    Quote Originally Posted by C16xe View Post
    Is the rear arb you have fitted come from ebay?
    https://www.ebay.co.uk/itm/182032468899
    And have you attached it with clamps?
    Yeah that looks like the one. It's the same fitment as a mk2 Astra ARB. I've welded some captive nuts in box section along where it was reqiuired to bolt at either end, no support required in the middle
  2. #4022
    Dec 2013
    Kings Hill, Kent
    1,897
    As Iain says my only worry would be too much castor, I've run 4 degrees and the thing steers itself and corrects itself when you loose the rear (bonus)
    Not sure how much would be too much!!
    I don't think we use much past 5 degrees but again that's due to space constraints.
    Be interesting to see how this works out.
  3. #4023
    Norwich
    5,659
    Stock Nissan S14s (what I'm running) have c6-7deg castor as stock I believe. Like you said - will be interesting to see where I can end up!
  4. #4024
    Jul 2002
    8,107
    Some great work!
    Would love a proper rear ARB for my Nova without the need for all the modification & and the price of a H&R item
  5. #4025
    13,605
    Cavalier one is bolt on using universal clamps and brackets, I've got one on my spare beam if you want photos for inspiration - PM me your number if you want a few pics.
  6. #4026
    Club Member Club Member JoeWak98's Avatar
    Mar 2015
    Cumbria
    196
    Could I have a few pics of the setup please Iain, have thought about adding another rear anti roll bar if it’s not so good on the back end
  7. #4027
    13,605
    Found some pics of the Cav ARB here: http://www.pngclub.com/forum/showthr...=1#post2230311
  8. #4028
    Mar 2015
    Cumbria
    196
    Spot on cheers
  9. #4029
    Jul 2002
    8,107
    Which Cav is the ARB from?
    I always thought they had to be modded to fit, never new they were direct with some choice clamps!
  10. #4030
    13,605
    I think it's a mk3?? I think some people modified the end brackets, drilled, welded etc, but yes that's the original end clamp+bush, half clipped over the edge and secured with a small bolt.
    It's copyrighted though, so you owe me if you do it too.
