Looking good mate
Getting better and better Simps![]()
Thanks fellas.
Front turret supports are now in place...
I’ve also reinstated the front posts for the slam panel & rotisserie mounts, although they will likely change once I’m done with the rotisserie.
Hopefully getting the shell home this week if the weather holds off long enough![]()
So June 2013 was the first prelim test fit of the engine to see if the project was viable...
Jan 2015 the body was removed from the frame...
June 2020 and the body is finally reunited with the frame!
I’ve now got some fiddling to do to get it in place (about 25mm back and 25mm down. I then want to check clearance of everything (especially the front turrets!) then I can get all the front end welded up.
That's a mile stone right there!
Yeaaahhhhsssss
