Results 1 to 3 of 3
Thread: 20seh throttle body conversion help - COILPACK
    May 2020
    8
    Default 20seh throttle body conversion help - COILPACK
    I’m going through the process of fully rebuilding my nova and need some help with converting to throttle bodies.
    I will be running a new ecu obviously but this requires a coilpack to run. Does anyone know of a suitable option that I could use? Would have to be converted from the current distributor unless I go down the carb route.
    thanks
    Sep 2012
    Sutton, Surrey
    3,766
    Go for a ford zetec coil pack, readily available and so are the plugs to install it to your loom, distributor can be blanked and run off the crank sensor only
    May 2020
    8
    Quote Originally Posted by millworm View Post
    thanks a lot. I’ll go down that route and probably start a build thread when all my parts come.
Tags for this Thread
