Worked on the subframe mounting points this afternoon. Very time consuming but pleased with the results.
These are 12mm ID, 20mm OD steel crush tubes. The hole needed to be 10mm offset from the tube centreline. So after some templating and tube notcher fettling this happened...
Other one done...
Then other side and subframe mounts done, subject to welding of course, which I want my mate to do as a proper welder person - they need to be strong.
Next up is the same for the tension bracket mounts!
Thanks for reading.
