Page 154 of 212 FirstFirst ... 54104144152153154155156164204 ... LastLast
Results 1,531 to 1,540 of 2114
  1. #1531
    Dec 2013
    Kings Hill, Kent
    1,897
    Got my nice new black trainers on!! Oh and the flywheel arrived!! 2.5kg
    All fitted up
    Measurements taken to check everything
    I need to make up a 2.4mm spacer to sit behind slave to get the minimum travel I need.
  2. #1532
    Dec 2013
    Kings Hill, Kent
    1,897
    Quote Originally Posted by Jonlem View Post
    Clutch is only there to hold the power, you won't even use it once you're out of the pit lane
    Happy to have helped out with some bits on the car
    Appreciate all your help and knowledge mate
  3. #1533
    May 2004
    Nr Cambridge
    2,594
    No problem. Look forward to seeing it on track 👍
  4. #1534
    chippy shoulder Admin
    Nov 1999
    Crowland, The Dirty North
    35,414
    18 Post(s)
    Love that House asked me to peer review his measurements while I was hammered in a field
  5. #1535
    Dec 2013
    Kings Hill, Kent
    1,897
    Quote Originally Posted by Stuart View Post
    Who better to ask than a drunken farmer??
    So I wasn't happy with my cam cover
    Went down to Modus and borrowed the blaster
    Then re-filled it, I'm not very good with filler!!
    Got it as good as could be, bearing in mind it's a cam cover not a show piece and this car ain't no show pony.
    Then back hammered effect hammerite which will be 2k lacquered to make it petrol resistant the same as my steering rack.
    I know everyone hates hammerite but it's thick, it filled the little imperfections and once lacquered it's harder than a coffin nail
    Rack looks alright in the silver with lacquer on it
    I can't be doing all this smooth stuff, it's too much effort!!
  6. #1536
    Ash vale, Hampshire
    1,474
    Yeah I have to admit I wasn't a fan of the cam cover before, black and understated all the way.
  7. #1537
    Dec 2013
    Kings Hill, Kent
    1,897
    Yeah the silver was only ever gonna be temporary but I couldn't handle it!! I should imagine this will get painted properly at some point!!
  8. #1538
    Dec 2013
    Kings Hill, Kent
    1,897
    Busy day today.
    Got myself up to Ben with the new slave and bearing to see what we could do with regard to spacing the slave off box.
    With a lot of tea fuelled debate, we decided that making a spacer behind the slave wouldn't be as easy as first envisaged. So we went with this idea
    I made the ring from a big bit of tube, tidied it up and parted it off on the lathe at 2.6mm
    Laid in place
    I pressed the bearing in and it's raised the slave retracted height to 46.5mm which means brand new clutch travel will be around 5mm which is perfect.
    Next, shift cut has been troubling me!! Some background info.
    The quaife box uses a potentiometer connected to the indicator to display gear position. My original intention was to simply piggy back the signal wire to the ECU and then as soon as the gear change barrel starts to move, the ECU would be programmed to cut the ignition.
    Here in is the problem, if the barrel is moving then the box is already trying to change gear but power is still applied. The answer is to fit some form of load cell to the lever so that as soon as the lever is pulled the ECU cuts the ignition and by the time the barrel starts to move the load on the box has been reduced and we're in business.
    Handily, quaife don't give any scope for a load cell on their lever, with the neutral interlock going up through the lever aswell so changing it isn't an option.
    Some tea and thinking later........
    One load cell, courtesy of James at Relenetless, I cannot speak highly enough of how helpful he has been.
    Some measuring and a bit of turning on the lathe led to this
    Then some sweating and measuring 5 times, I had to cut down the end of the gear level push rod
    A bit more turning and some clever tapping, half of the middle spacer is tapped 1/4UNF the other half M8x1.25. Put together and tightened up
    When all was said and done, you can't resist a bench test!! I grabbed a false neautral between 2/3 cos the lever was only held by a bolt in the vice, when the input shaft is spun and the lever pulled properly all gears work beautifully, I even setup and adjusted the neutral interlock, so that's all done ready when it's back in the car
    https://youtu.be/fqqHjwmbHfg
    Oh and the shell will be in primer by Friday
    Should see some colour by next Friday and be back with us roughly on schedule.
  9. #1539
    May 2004
    Nr Cambridge
    2,594
    You don’t hang around do you. Nice job with the load cell
  10. #1540
    13,605
    Can't wait to see it painted
