Page 398 of 410 FirstFirst ... 298348388396397398399400408 ... LastLast
Results 3,971 to 3,980 of 4099
  1. #3971
    leeds
    1,336
    3 Post(s)
    How did you do your wiring for the MOT dash lights?
  2. #3972
    13,605
    Quote Originally Posted by boffer8 View Post
    It's all using the original wiring that went to the clocks. Just one wire to Led and the other to live or earth depending what it's for.
  3. #3973
    23,816
    Liking the upgrades.
    Very interesting about the dash lights. Somethings i've been thinking of.
  4. #3974
    13,605
    Onto the exciting updates, leading to my first test drive in months today.
    Gearbox, I'm now using a Quaife SCCR 4.2 with Quaife ATB diff. It came with the short option fifth gear, so I've swapped in the middle option.
    Unexciting looking box:
    Removed fifth:
    Shiny new one:
    Onto the engine, I'm using the one from Houses red shell. Bottom end is 86.5mm with standard recently rebuilt crank/rods. However I wanted to use some bits off mine, namely the oil pump, pickup and cams. Both out for surgery:
    Now there was a slight issue, when the car came to me it was running on 3 cylinders. Turns out a snapped valve spring cap resulted it holding the valve open. Eek.
    Head off for inspection:
    Intake ports look nice, think it's worked a little bit:
    New stem seals:
    And cleaned valves and seats:
    On and fitted with Kent AST1612 cams:
  5. #3975
    13,605
    Sump required fettling, my modified one bottom and new one on top received the same treatment:
    Also made a little speed sensor, trying to use the middle CV as a speed sensor:
    Finished and painted:
    Onto the fueling side of things... The carbs are gone. So I've fitted an in-tank Walbro 255 pump to go with my SPI tank, very neat solution:
    Finished pump:
    Fuel system is all AN fittings from the push-fit pump and fuel return on the tank side, with filter in the original location:
    And internal braided lines:
  6. #3976
    13,605
    Onto the bay side of things, the horn got relocated behind the wing for more space:
    And the FPR and new Mocal catch tank mounted on the strut brace:
    Now onto some more juicy stuff robbed from Houses shell. Jenvey DTH throttle bodies with carbon trumpets:
    Bish bash bosh:
    Throttle cable sorted thanks to a handy kit from Venhill:
    And she runs:
    Finished engine bay, looking good:
    I'm also using the full Powerflow stainless sytem from Houses shell, although it's built for a mk1. Undecided whether I'm going to redo the tailpipe or not:
    First daylight in months and months:
  7. #3977
    Feb 2013
    Scotland
    248
    Looking great!
  8. #3978
    Dec 2013
    Kings Hill, Kent
    1,897
    Poor old House you stole all his parts
  9. #3979
    brotton , saltburn by the sea
    1,876
    Nice looking machine . Ps i think the tailpipe looks great as it is
  10. #3980
    23,816
    Loving that! Tb's are a great add on.
