Few additional pics
Few additional pics
Nice, very nice.
very nice!
what alternator are you running?
edit: do you have more info on the brake switch you use?
it looks like to be an very small pressure switch?
Yes, they come with a single V pulley as standard. I swapped that for a 4 groove alloy pulley from Brise, as well as a Titanium retaining nut. Total weight of the alternator is about 2.5kg.
Great way to save weight and space, but shop carefully, you definitely are better off with a genuine Nippon Denso item. There are huge numbers of aftermarket copies, and they just aren't of the same quality.
I can give anyone the part number if they want to get one.
Few more pics
In a few twists and turns, using the unit as storage only now, not happy with security for the car down there.
So
25mm on the walls
75mm on the floor
Flooring tiles down, not the best brand but they're good enough
Shelving over the toolbox
25mm up inside the roof too
With the car hard over I can get a metre on the opposite side, the doors will be removable so I just need to figure a way of moving it easily on the rally stands
Plenty of work space up in front too
Got the tool box back in there today, using the roof-space as storage, plenty of space up there.
I've got an air conditioner/air source heat pump coming, I can get it to stay at around 12 degrees with a small oil filled rad whilst it's been 1-2 degrees outside.
