Still enjoying your thread House, it’s come a long way recently so keep going![]()
I love a waffle, get some syrup and ice cream on it and that’s perfection!
I'll have a look, cheers
Few bits sorted today. Lots of little jobs but they all add up together
Switch panel box all mounted up, with fire extinguisher pull and the bottom one will be heated adjuster
Catch tank mount
Overflow rad back to header tank done in tube
Added the bottom header tank to the bottom rad hose
And heater return
Dash 2 mounted, with the quaife gear indicator in a good position too
Cold air feed for the blower is fed from inside the passenger chassis leg, holes to the engine bay and outside sealed up, not perfect but the best solution we could think of
One side of the screen blower complete, passenger side tomorrow.
Sick.
Another good day up with Ben today
I started off on the mill, while Ben made some slugs to mount the fuel cradle onto.
Mocked up in the car for bracket manufacture
Picture looks squiffy but they’re straight enough in person
Next up
So this is for a Corsa B, which meant the roof bend wasn’t perfect for what we needed, only one solution, choppy choppy
Fit is much better, out with the drill, whilst I was happy using the mill, this needed Ben’s steady hand!!
Big roof hole
Played around with some door handles, maybe not the final version but something like this
Tempted to mill the centre out completely, now I just need to get the fibre glass doors cut out with the die grinder for the handles and locks
Boot lid next, ditched the hinges as we couldn’t find any hinges in stock to bolt to the boot lid and even with the hinges on you still have to cut the ones on the car off and re-weld them in a different position, see Iain’s thread, even after doing all that it’s still not possible to open the boot lid all the way and even then there’s no stay to keep it open. Therefore, Boom removable boot.
So the jobs are really getting a line through them fast, we are hoping that by Friday next week 98% of the work will be done and we can get it off to the exhaust place for them to do their thing, then it’s booked in for the plumbing to be done first week of Jan, hoping to see it in paint by first week of Feb.
I also learnt that you should never drink and order tools
Boot is way better like that than hinged. Great progress as ever.
