Page 11 of 23 FirstFirst ... 91011121321 ... LastLast
Results 101 to 110 of 228
Thread: Rally Car Build
  1. #101
    Oct 2011
    358
    Quote Originally Posted by scottmasterton View Post
    Hi Paul from what we've seen this should be ok as it's been done before on novas that have an MSA logbook 1 and harry hockly do it to there swifts and similar.
    Under the impression it more means that turret location is not allowed to be altered and similar to prevent things such as inboard setups but will see if can speak to a scrutineer
    Thanks
    I wasnt sure if the Hockly cars were cat2 modified rather than cat1 due to this. I know of a rwd car recently done with bulkhead mods (to move engine back in the bay) that forced it to be cat 2 passported rather than cat1. I guess asking MSA technical would be the best most foolproof way to go at this stage as a written answer from them will be hard to refute when the passporting process is done. Wouldnt have wanted you to finish the whole process then the MSA refuse to issue a passport!
    Paul..
  2. #102
    Feb 2013
    Scotland
    248
    Quote Originally Posted by RallyMarshal View Post
    Paul..
    Just spoke to someone that used to work for M Sport and they were one of the ones suggesting/agreeing with the IRS in the first place he seems to think it'll be fine. Prior to starting we found quite a few cars with their own versions mainly Corsas but most of the corsas were built to a S1600 spec. Not quite sure if thats cat 1 or what.
    Agreed that would be a total nightmare! Will keep you updated via the thread as to what we're told by the MSA
  3. #103
    Feb 2013
    Scotland
    248
    Had a mate come do some welding, feel like we're really getting somewhere now
    More prep work to do before he comes back on Monday and that should be the topside rear work done
    Sent from my EML-L09 using Tapatalk
  4. #104
    Feb 2013
    Scotland
    248
    Thats the floor almost done with the little plates added in to meet the cage
    Seam welding done topside and battery box mounts welded in
    Steering rack strengthener bracket in
  5. #105
    13,605
    Lots of roll cage! Should be stiff enough!
    I saved a good amount of weight and complexity by mounting my battery in passengers footwell. Have you thought about putting it there? Much shorter run to starter motor.
  6. #106
    Feb 2013
    Scotland
    248
    Didn't look at that to be honest, bit late now plenty of other ways to save that sort of weight
  7. #107
    Feb 2013
    Scotland
    248
    Got the shape for the rear tank guard and the front sump guard
    Compression tested the engine, It's goosed as we thought - making around 60 psi on each cylinder
    Took the engine out and stripped everything else off the shell to get shell back on the spit
  8. #108
    Feb 2013
    Scotland
    248
    Pedals just needing last bit of cleanup, a spray and some grip tape
    Started mount for wiper motor
  9. #109
    Feb 2013
    Scotland
    248
    Some more progress
  10. #110
    Sep 2012
    Sutton, Surrey
    3,761
    Top work mate
