Page 566 of 569 FirstFirst ... 66466516556564565566567568 ... LastLast
Results 5,651 to 5,660 of 5684
Thread: Benn's on going build
  1. #5651
    23,816
    Ah nice, but unsure what i'd use it for...
  2. #5652
    2,618
    The scuttle cover!
  3. #5653
    23,816
    Oh!
    Normally i have it flocked...
  4. #5654
    23,816
    I do seem to be slacking at adding updates..
    Where did i get too? Ah yes, engine running like crap all the time. So only one thing for it... Aftermarket ecu and custom loom.
    So out with the old... remove the old loom and started mocking up for a custom loom all hidden away... As i do.
    Found out that i can run the coil on plug set up.. Thought why not.
    Using Toyota yaris coils...
    You need to drill the cam cover for the coils to bolt down too.
    Very important bit! You'll need to shave down bits on the cover due to the plugs on the coils...
    Due to the COP, the dizzy could be binned off...
    Before,
    Off,
    SBD Dizzy blank.
  5. #5655
    23,816
    Wasn't quite shiny enough for me...
    Lil bit better..
    Had to have polished bolts..
    Left is before, right is after. good old stainless..
    Both polished.
    New injectors where fitted. Siemens 650 ones, Tiny they are.
    While i was doing this a very nice man made me custom loom up to what and what i wanted...
    Looking nice...
    Yummy!
    Time to fit...
    So nice using a loom thats new, nice and uncut. Some might say porn.
    Up the inner wings for maximum hiddenness.
    With the bonnet cable. Polished stainless P clips too
  6. #5656
    Jun 2009
    Newark
    4,682
    Nice work. Notice any differences? Has it got a speed sensor mapped in to aid with traction?
  7. #5657
    Club Member Club Member CorsaBBoomer's Avatar
    Oct 2006
    Belgium
    396
    Everything you do to it makes it better and better...
    Opel Corsa 1.6 Michalak 1986 : http://www.pngclub.com/forum/showthr...ect&highlight= Yes, it's a convertible with a hard-top!
    Opel Corsa 1.0 1983 "Josefien": http://www.pngclub.com/forum/showthr...ien&highlight= Miss I-Went-International
    Opel Corsa B 1.5TD 2000 "Bertha"
    Citroen AC4 1929 "Clarice"
  8. #5658
    Dec 2013
    Kings Hill, Kent
    1,897
    What ECU big man??
  9. #5659
    23,816
    Quote Originally Posted by Balley View Post
    It starts on the button and runs so much better, but cant really use it yet.
    Quote Originally Posted by CorsaBBoomer View Post
    Thank you Sir.
    What ECU big man??
    Dta S40 pro.
    Checks Mig facebook, there is a awesome nova on there you NEED to see. And i can tag you in it.
  10. #5660
    23,816
    Missed the last bit off....
    Off to Track and Road for mapping. Many stresses before hand!
    Starting mapping.
    THis is where bad luck hit.
    Car starting smoking. No clue why at the time.
    I left T&R very unhappy and very wet. (started to lash down while loading it on the truck)
    Mapping was stopped with just the low down useage settings done. So i can move it around on the drive. But thats it.
    Steve and Jim at T&R Suggested a few things to look at.
    My cam cover main breather was kinked, sorted that but still puffing.
    So got a leak down tester to check the rings, all seem ok. Compresion test done, all where the same.
    Noticed my dump valve had blow oil out of it...
    Took it off to find...
    Oh thats alot of oil... About half a liter was sitting in my intercool.
    So Dan suggested taking the down pipe off to check the turbo.
    There was alot of movement in the hotside.
    Turbo stripping going on.
    Turbo in bits..
    Alot of oil was in the cold side.
    That's where i'm at.
    Turbo is off being rebuilt as we speak. Fully back this weekend to rebuild it.
