I'll have to dig out a pic of a similar spacer a local lad knocked up for s similar issue. You will chuckle !
I need a shonky gm sticker for the saab
PROJECT 2 FAST 2 FAT clicky
Good work!
Glad to hear that everything is working as expected....and you have solved the CV explosion problem. Thanks, that saves me some work.
I still have a 20 mm longer shaft on order to fix it properly without extra angle on the CVs.It has been good learning how to measure plunge though.
Luckily nothing bent but loose ball joint bolts explain the knackered steering after the spin.
https://youtu.be/cjKWx5TGls8
I'll be at Billing Sunday potentially with nova if anyone fancies saying hello.
Yeah a fairly big moment there on track; love the catch on the longer video however!
