Wear on the outer edge means it's rolling over the outside edge of the tyre and not using the full contact patch. Do you seriously think you'd wear a tyre perfectly evenly on a track on standard suspension?
He just wanted an excuse to buy it!!!
Anyway, wear on the outer edge is caused by a lack of camber and caster, meaning the tyre is riding onto the outer edge during cornering and as Iain says not applying the full contact patch to the track surface.
This would happen on standard suspension also, it would in-fact be worse on standard suspension, the only way to solve it is add camber and caster, either with eccentric top mounts or the aforementioned suspension set-up.
With the addition of either of these 2 things mechanical grip would be vastly improved, the suspension kit more so.
Does look good on yours!! I was gonna get a similar kit but you didn't want me to copy you.
Just keep a spare set of new ball joints in the track day box, cheap, easy to change. win win
http://www.santafegarage.com/precisi...ber-explained/
interesting read
i didnt say on track, having perfect tyre wear is what people desire on road cars, which means comprimising on handling and performance.
wear on the outside edge doesnt only mean its rolling over, is your track set up to toe in? all circuits are differant and are going to affect the tyres in ways you wont be able to foresee unless you use that particular circuit often. I mean look at the F1, they practice all day friday, qualify on the saturday and still can get undue tyre wear on the sunday.
I'm not far behind F1 in terms of my vehicle set up capabilities.
It's set up slightly toe out. It was previously 0.75 degrees camber and not much caster, now it's at 1.5 degrees. The competition build manual says to run more camber than I was, and am, doing. The Michelin slick manuals also suggest more too from what I remember.
I've been using these slicks on track for years so I'm optimistic I'm doing the right thing. And if it doesn't work out too well, I can dial it back in a bit, no biggie.
I bet you are glad you took the time to update the thread now Iain.
