Page 350 of 410 FirstFirst ... 250300340348349350351352360400 ... LastLast
Results 3,491 to 3,500 of 4099
  1. #3491
    13,605
    Couldn't be bothered with the manual brake bleeding so took one of the reservoir caps and popped off the internal splash guard
    Drilled a 10mm hole
    Which allowed me to use the Eezibleed pressure bleeder
    Finished
    A quick test drive up the garden proves it works although braking was incredibly poor.. Hopefully due to the new discs so will bed it all in and see where I'm at.
  2. #3492
    Oct 2011
    358
    Bigger legs needed :-)
    Paul..
  3. #3493
    Senior User Club Member
    Apr 2003
    South Wales
    6,566
    Ha - I did exactly the same to bleed mine - worked a treat.
    And initially, the bias box will feel like nothing's happening - especially if you've got pads that need heat in them to work... I regularly get into the Nova out of a normal car and nearly sail through junctions, read-faced and sweating!
  4. #3494
    13,605
    I drove at probably less than 10mph and struggled to stop within a 3 metres, need to bed stuff in properly and see where I'm at. Got Mintex 1144s in at the mo.
  5. #3495
    23,816
    Wont the pressure just blow the tape off?
  6. #3496
    13,605
    I have a new cap on order, however the reservoir isn't pressurised, the master cylinder just draws in what it needs.
  7. #3497
    23,816
    Oh ok, i thought the bottles would be too. Thank you.
  8. #3498
    13,605
    Well my issue was pressure bleeding from a dry system, there must have been tonnes of air in the master cylinder (between the push rod and outlet I imagine).
    What you're supposed to do is something called 'bench bleed' the new cylinders; plenty of resources online about doing this.
    So instead of removing them from the car, I got them level and looped my new lines back into the reservoirs:
    Then topped the brake fluid up to create a looped system
    Lots and lots of pumps of the pedal later, I've reconnected up the system and pressure bled as before. The cylinders now travel a hell of a lot less and the pedal moves lots less too, much more like I was expecting it to.
    Test drive later to bed in the front pads and find out if my pedal ratio is usable...
  9. #3499
    Sep 2008
    West Yorkshire lad
    22,243
    6 Post(s)
    1 Thread(s)
    Glad I asked if you'd bled them up okay
  10. #3500
    13,605
    Southie wins a gold star.
