Page 197 of 230 FirstFirst ... 97147187195196197198199207 ... LastLast
Results 1,961 to 1,970 of 2292
  1. #1961
    Norwich
    5,659
    So not a huge update but managed an hour tonight between commitments. Continued to make templates for the flooring. Its a PITA to be honest and will be so much easier once I can remove all the running gear and turn the shell upside down.
  2. #1962
    2,618
    Are those flat pieces staying for the seat mounts?
  3. #1963
    Norwich
    5,659
    That is the plan yeah. I know usually people tie them into rails running left to right but this seem simpler in my set up. The plates are 5mm thick but to add strength and stop flex i was gonna to to panel the sides to box in with the floor. They also need welding fully to the tube work. For access to the fixing nuts underneath i was going to cut access holes in the floor then bung them.
    See any problems mate? I'm all ears.
  4. #1964
    23,815
    Yay, glad you've had a lil time.
  5. #1965
    User Club Member
    Oct 2006
    yorkshire
    1,024
    Just gone through this thread like jonny-5 on crack.
    Best thing I've seen in ages ��
    Lee
  6. #1966
    Norwich
    5,659
    Cheers Lee
  7. #1967
    2,618
    What I mean is you've crafted a wonderful structure from tube overall to then just stick 5MM flat sheet on top. Is there not a smaller ID tube you can then weld captives onto?
  8. #1968
    Norwich
    5,659
    Oh I see! I think once boxed in it will look ok but I take your point. I just can't think of how to sensibly do it in tube without over tubing the area (yes, I am aware in the irony of that statement! ).
  9. #1969
    Norwich
    5,659
    So decided tonight that I would drop the running gear and flip the chassis over, making it a million times easier to finish the floor! All was going smoothly until A wheel buckled on my little trolley that was meant to roll the engine out the way. Need to get me a crane sorted out now...
  10. #1970
    Oct 2010
    oddthorpe
    507
    personally, i dont think you have enough axle stands in that garage
