Page 123 of 135 FirstFirst ... 2373113121122123124125133 ... LastLast
Results 1,221 to 1,230 of 1345
Thread: Edd's Nova Sport
  1. #1221
    Sep 2008
    Bridgwater
    12,248
    all i achieved today was making it not start at all
  2. #1222
    User Club Member
    Aug 2015
    Derby
    440
    Quote Originally Posted by Edd View Post
    Gutted for you Edd - so near to an almost perfect Sport and disrupted by what will no doubt be something stupid and electrical!
  3. #1223
    Dec 2011
    Fife,Scotland
    1,138
    Nova tat
  4. #1224
    Sep 2008
    Bridgwater
    12,248
    indeed, complete and utter tat
    plugs got soaked in petrol, so im guessing that's me needed a new set
    i will sort it tho
  5. #1225
    Sep 2008
    Bridgwater
    12,248
  6. #1226
    Sep 2008
    Bridgwater
    12,248
    That's my pulley
    As you can see its set with the pointer on the large original notch
    But there is a notch on the outside of the pulley
    I'm guessing that one is for unleaded petrol???
    I'm on the verge of taking it to garage now
  7. #1227
    Senior User Club Member
    Apr 2003
    South Wales
    6,566
    Why not just have a play with adjusting the timing each way - and see if it makes any difference... if it does, you know that will be the answer?
  8. #1228
    13,605
    What would that be a tooth over on the cambelt? Gotta be worth a try.
  9. #1229
    User Club Member
    Feb 2014
    Wrexham
    573
    As far as I am aware there should only be a notch on the inside of the pulley. Will double check mine for you if you like?
    What petrol it is running should not alter the cam timing. Only the distributor needs adjusting for differing petrol, although mine has not been adjusted since changing to super unleaded. Was told by my old Motorsport engine builder that as long as it runs ok don't touch it as petrol these days is so much better.
    did post a pic on the other thread.
    definately worth checking cam timing is not out.
  10. #1230
    Sep 2008
    Bridgwater
    12,248
    What's pissing me off is
    - Cam belt timed up with no1 at tdc and pulley notch in line with pointer
    - Ignition timing set with a gun with notch and pointer lined up
    That should be job done
