Page 540 of 569 FirstFirst ... 40440490530538539540541542550 ... LastLast
Results 5,391 to 5,400 of 5684
Thread: Benn's on going build
  1. #5391
    23,816
    Quote Originally Posted by House1983 View Post
    Looking at your cooler take offs mate, the radius of the 90 is quite big, your route is similar to mine but i dive left across the car to my cooler where you go right.
    These would keep the hose tighter to the engine, you could then double clip it to the inderside of the chassis leg on the engine bay side of the lip so they're protected from the tyre?? Can use them with rubber hose similar in coiloir and style to what you have now (from the pics)
    Mine are mine longer, tighter smaller ones would be good, can you link me too them?
    Yea they are better as above really. Mine are much longer, i'll get a pic. ** Also is that a crack by the nut from the sus arm on the chassis??
    You should avoid using forged fittings on oil. Swept every time.
    Which are forged? Mine came from a hydro place so he knew mine where for oil.
  2. #5392
    Apr 2011
    wiltshire
    1,938
    Just remember seeing this on SBD's instruction sheets when plumbing in mine, that's all.
  3. #5393
    Club Member Club Member TallDave's Avatar
    Nov 2013
    Southampton
    132
    I'd reinforce Craig's opinion on this, definitely avoid the square bends that cast fittings tend to make. Interestingly when you look at the details of the 'Torques' Cast Fittings on their eBay site, when you scroll down to read the details is shows proper radiused fittings which you should use.
    Basically swept fittings result in smooth oil flow, whereas cast fitting result in a disrupted oil flow...
    Froth on beer = good, froth in oil = bad!
  4. #5394
    13,605
    Just grubby in a seam I think! Shorten yours and run them below, it sits there lovely
  5. #5395
    Dec 2013
    Kings Hill, Kent
    1,897
    Sorry chaps, my bad, I've got the wrong picture!!!
    These are the ones I used, they also do one that uses push on rubber hose.
    Dreadful pic but you can see they turn a lot closer,
    Search AN8 90 on eBay and buy from "torqes" you can buy the bends and all the adapters you need, the sandwich plate is m16x1.5 to AN8 that's the adapter I used.
    Any questions just shout mate.
  6. #5396
    Apr 2011
    wiltshire
    1,938
    At the risk of sounding like an asshole I would disagree with that too. AN10 minimum on a pressure line, and the ULTRAFLOW fittings tend to be more compact.
    I have these on all of my pressure lines.
  7. #5397
    Dec 2013
    Kings Hill, Kent
    1,897
    Mate, you won't sound like an asshole if what you're saying is right and I'm almost certain you are right cos I know *u*k all!!!!!
    I said to the guy at Torques what I was doing with the fittings and he sent me the right ones, now I know he messaged me and said I'd selected the wrong fittings for my SS braided hose so it's possible that the ones I pictured aren't the right ones and I'm 300 miles from the car so can't get any pics and don't have my laptop to see what the eBay message says!!
    My mocal cooler has AN8 fittings welded into it so I just assumed it would be AN8 and carried on.
  8. #5398
    Apr 2011
    wiltshire
    1,938
    Actually, thinking about it this is just a cooler isn't it. -8 may well be fine, I'm comparing it to mine which is in the return to tank line in -12.
    Going back to Ben's car, maybe just re-do it how it is and fit some steering lock stops
  9. #5399
    Senior User kevster's Avatar
    Oct 2003
    worthing
    2,874
    Like the idea with the air filter Ben ! What's the benefit of running a cooler anyways ?? , I'm not running one on mine I've got a cosworth oil separator .. Or have I maded a boo boo
  10. #5400
    Dec 2013
    Kings Hill, Kent
    1,897
    Steering rack limit would work, I had this on my MI16 pug 205 to stop the wheel touching the gearbox casing!!
