Page 534 of 569 FirstFirst ... 34434484524532533534535536544 ... LastLast
Results 5,331 to 5,340 of 5685
Thread: Benn's on going build
  1. #5331
    Feb 2010
    Teesside
    112
    I've always enjoyed your build thread Benn, I like all the unique personal touches you've made....
  2. #5332
    23,816
    Quote Originally Posted by kevster View Post
    Nice work mate
    THank you.
    Quote Originally Posted by LDAWSON View Post
    Thank you very much.
  3. #5333
    User Club Member
    Oct 2006
    Belgium
    396
    Benn, you even sprayed the rod ends... You make me want to do my Michalak all over again
  4. #5334
    23,816
    Yea, the finish wasnt great and time have time to chrome them.. I know only a bit of them is seen, but want right..
  5. #5335
    23,816
    One thing i was never happy about with my seats, is the fact that who ever re trimmed them had cut holes on the insides of them for the pulls (to flip the seat forward)
    Which these seats dont have... I've tried a few things but never been happy with them.
    So this time, i got one of these...
    Cut a bit of plastic and did this...
    Then weld it in..
    Sand it off..
    Gave them a very quick skim of stoppper then sanded that off then popped to see a man that does Flocking...
    Colour looks a little diff, but it's just the flash...
    Gaps filled and look better.
    Will get better pics when the cars out of the garage.
  6. #5336
    Senior User kevster's Avatar
    Oct 2003
    worthing
    2,874
    Cracking idea you had there Ben !
  7. #5337
    23,816
    Cheers Kev, good thing is cause the way the seats are made. The have the holes both sides, so the trim still clips in proper.
  8. #5338
    Apr 2007
    Old Radnor, Powys
    2,803
    Nice little touch benn.
  9. #5339
    23,816
    Thanks Bruce.
  10. #5340
    23,816
    A while back i stripped a spare rack i had, i've polished my rack before but it dulls very quick as it's very hard to clean. So this time i had it chromed.
    With it all apart i wanted to get all new bits, new rack arms and ball joints and bearing. Plus new boots.
    Today was finally time to rebuild it, but sadly with no new bearing.
    This is the shaft the bearing sits on.
    I took it the bearing would press over over the gear bits. But no.
    As you can see here there is a big lip that side, i found this after breaking the bearing with the press then cutting the last bit of race off.
    So it must press off from the other side, That bit must press off.. If it does i couldn't get it to move. Ended up just damaging it. Alot. So i've had to leave the bearing on and just re-grease it. (was no play in it so should be ok)
    Dirty job, but my own fault as i used to much grease.
    Built up. The chroming isnt perfect due to all the shapes to get blow from. but it will do.
    Use these nice polished stainless jubliee clips on the bigger side of the boots.
    Didn't have the same for the small one tho so used polished GM ones.
    Boot wise i wanted the hard style plastic ones. Which i couldn't find anywhere, only the soft floppy rubber ones.. Don't like them.
    So i set out to use the ones from the rack before...
    Before.
    After.... A trip through the dishwasher.
    And a wipe over with some cleaner.
    Then i gell'ed them up.. haha
    All ready to fit at the weekend.
