Pimpin' steering rack, are you going to have it chromed?
If only I'd i've known mate, I'm sure I've got a brand new rack in the shed somewhere (probably covered in grinding dust tho!)
PM sent
Sorted.
Not much happening on the car at the mo. Battery died, replacement at my work. Am thinking off fitting EPas as well as a few other winter jobs.
Sump leak is one of them and maybe a join fitted in to my exhaust too.
Mines never stopped. Might take the engine out and do it that way..![]()
I did that, it still dripped. Different sump now, had it check and filed to be 100%flat. Hoping it was the heat from polishing that maybe warped the edges on mine now... Pisses me off it dripping.
You could look into a brand new steel sump Benn to try and tackle the problem. I started researching about it, you possibly need a different pickup too. Only worked out something like £35 for the sump new.
