I really need this to go now,as change of career has forced this to go now
engine spec
• 1998 Rebuilt C20LET engine, covered approx 8,000 miles, ported and polished Coscoast cylinder head, arp head stud kit and arp rod bolts, duel layered steel head gasket, xe inlet cam, ngk plugs, 8.5mm magecor leads, full roose/samco hose kit in blue, paddle clutch brand new, pot type lightened flywheel, front mount including 2.5” hard pipe kit with hoses and clamps,up rated oil cooler, radiator, fan. Owen Developments GT2860rs turbo, Nortech manifold, Turbosmart 38mm racing external wastegate and screamer pipe, with fixings – (all new in may 2008, receipts total £1807.16) - covered approx 4,000 miles –has just had new cambelt kit (gates one) and water pump,also custom inlet manifold made by(novarick) has a v6 throttle body on,has mbe ecu, its got a sbd coilpack and qed blaniking plate,has got a txautosport metal water pipe,plus brand new roosemotorsport 3 way water pipe ,needs mapping and got a spare let loom if needed(some plugs are missing due to making mbe loom up) £2000 Ono
engine needs mapping as not on base map
any more pics just ask
This is every pipe ie coolant,boost pipes all included
Can do a deal with the f28 if bought with engine
Also once the engine has been sold the rest of car will be getting pulled apart
Contact number 07572421794
