Thank you and no, less is more? Stripped with cage? I've done stripped out, got bored quick, very loud,can't take anyone with ya and that..
Cheers dude and i have no clue, you should read it from the start...
Thank you![]()
Thank you![]()
I'm looking forward to having a nosey round this at the weekend!
Got all my door cards fitted, with newly flocked surround.
Wanted to get the boot on so i can start flat and polishing in the morning. So, newly repainted hinges..
Had to make a temp spacer as one got broken when removing/drilling out the bolts. Want to give the holes a counterink and fit the right kind of bolts.
Now the fun bit, bolted them on but so i could still move them, fitted the boot to check everything lined up ok. Luckly i looked at Craigs Nova in the bodyshop and did a quick finger measurement.
Then nipped them up tight. Remembering to wipe a small amount of sealant on the backs/faces as the holes in the shell are quite large. (cleaned back now)
Another reason i need different bolts...
Tomoz i can now flat the roof and then polish it and clean the car.
Pretty much all back together now?
Need to flat and polish the roof, then maybe fit and flat and polish the bonnet then clean it.
Superb! Hey benn what door carpets are these?
My door cards are custom made.
Still very much in love with your nova Ben , good lad .
