Page 296 of 410 FirstFirst ... 196246286294295296297298306346396 ... LastLast
Results 2,951 to 2,960 of 4099
  1. #2951
    13,605
    Got steel here if I want to do that cheers! Bit of a bugger for access with the oil cooler and radiator in there to start plating it, that and I worry it's going to look like a patchwork quilt if I keep adding plates!
    Iain, I've got a mk4 Astra turbo splitter that has holes in the splitter and the plastic ducting vents to allow brake ducting to br routed etc, let me know if your interested an you can have it for what I paid posted etc..
    Sounds interesting, any pics of the ducting attached to one? I have the air duct splitter-end pieces from a 7 series I was going to mock up today but forgot! These ones:
  2. #2952
    Senior User pie's Avatar
    Jan 2009
    Blackwood gwent South Wales
    6,769
    astra coupe uese brake ducts also zafira's in the splitter
    astra gsi ducts
  3. #2953
    Dec 2003
    18,397
    The ducting is attached to the back of the platter for the cope turbo one, no pics I'm afraid, not at home at mo either, try Google mate.
  4. #2954
    May 2012
    derby
    44
    Quote Originally Posted by Edd View Post
    The pic that Pie posted looks a decent idea
    What I was getting at is that all this effort to route some airflow towards the brakes is not going to be worth it, you'll never tell the difference and would be better off putting tme and money into something else on the car
    All IMO of course
    you wernt in the car going flat out at donnington in the passenger seat when he sat there, 2 inches from the chicane when he said 'oh my god karl i have no brakes' que an oh f**k clench from my balloon knot!
  5. #2955
    Oct 2012
    949
    Rang Beevers auto panels in the week to order my rear quarters. Made it quite clear I was going to pick them up to avoid damage (as recommended by Paul off here), thought that was that and then they arrived in the post
    One is good:
    The other is damaged:
    So will be ringing them on Monday and asking for a replacement... Collected, if they know what that means.
    could you mail me there address for these panels mate many thanks
  6. #2956
    Dec 2003
    18,397
    Dude here's the mk 4 turbo splitter with ducting
  7. #2957
    13,605
    Quote Originally Posted by shaunboy84 View Post
    I think Beevers went under/stopped trading a little while ago mate, sorry.
    Cheers for the pics Scott, I have some parts collected and a plan to hopefully execute tomorrow weather dependent so I'll post up how far I get
  8. #2958
    13,605
    OK here's what I've been up to the past few weeks
    Finished my crossmember repair, primed and painted:
    While I had the paint out I thought I'd plan ahead and cut away some of the crossmember to match the wings:
    Also fitted my new Powerflex ARB bushes:
    What's left of the FloFlex ones after barely any work, one's split already:
    On with the brake ducting...
    The pic someone posted previously with the Vauxhall ducts, managed to borrow a pair off Harvey for use on his mk2 Astra:
    They're very far off fit-and-forget really, as the angle of the tiebar/bottom arm is vastly different to the bottom arm angle of the mk2 Astra:
    So I'm proceeding with the ducting idea. Seeing as the proper scoop ducts are £40 a pair, and the Revotec machined alloy intakes are £20 a pair, I bought these plastic intakes for £5 posted the pair, cheapness ftw
    Utilised my cut-down crossmember and drilled/mounted them in the bumper like this:
    Duct can come along here:
    Will be attached to the lower arm/ARB like this:
    And up to the rear of the knuckle like this, to point at the middle of the disc. I will make something up for the end of this pipe to channel air into the disc even more, like Mowgli suggested.
  9. #2959
    13,605
    Needed some new dry trackday tyres so purchased 6 19/57/15 Michelin S9C tyres:
    Needed to test fit them front and back to make sure I wouldn't have any clearance issues, but they fit well:
    Looking forward to trying them out!
  10. #2960
    Jan 2007
    10,358
    wont the pipe get ripped to peices by the tyre when turning in now?
    PROJECT 2 FAST 2 FAT clicky
