Page 462 of 569 FirstFirst ... 362412452460461462463464472512562 ... LastLast
Results 4,611 to 4,620 of 5684
Thread: Benn's on going build
  1. #4611
    Jul 2008
    Unknown
    9,635
    The grille design how it clips in the wing is a **** design should of adapted the mk1 way with bolts
  2. #4612
    Apr 2008
    Aberdeen, Scotland
    4,025
    Love this car, shame about the grille. Do you have another one?
  3. #4613
    Old User
    Jul 2007
    somerset
    2,968
    Glad to see your still getting your hands Dirty !!!! sh1tter about the grille though !!!!
  4. #4614
    User Club Member
    Oct 2006
    Belgium
    396
    They have a course for that here: anger management
    Good you left it there and then, I've had similar in my 5 years on the Michalak.
    Nice welds, good job
  5. #4615
    23,816
    Quote Originally Posted by fearless View Post
    Looking at your inner CV joint failure pictures i'd diagnose your problem as Insufficent drive shaft plunge !!!!
    Place a 5mm spacer between the cv joint and the wheel bearing/hub - althought you will have to redrill the split pin hole on the joint as it will no longer be visible when the spacer is fitted !!!
    Dave
    BroadGhost and Lee303 have talked of the same, i have the shaft rebuilt now but with cv boot off, so i can look at the movement and free movement when its sat straight and then where the steering is turned.
    Would the spacer do the same as getting the circlip cut out moved down? As that means the shaft will sit deeper in the knuckle meaning less stress on the knuckle and cage?
    Quote Originally Posted by brainsnova View Post
    Yeah is very annoying. But the tight fit made it fit nicely..
    Quote Originally Posted by bazzap8389 View Post
    Only a less nice one i use for track, but i'll get another. Thank you very much too.
    Quote Originally Posted by GRUNT 16V View Post
    Always.
    Quote Originally Posted by CorsaBBoomer View Post
    I'd fail it! haha, tbh i had to just walk off and leave it. Welds are ok, wasn't worried about a nice weld, just wanted it on there and strong so i could get the joint out. But happy they seem to be very strong and penetrated well going by the heat colouring.
  6. #4616
    Club Member Club Member fearless's Avatar
    Mar 2003
    Manchester
    1,289
    Correct -Driveshaft plunge is 15mm AFAIK measured at full droop, undo the castle nut and make sure the inner joint is pushed in then measure how far you can push the outer CV joint in until it stops, then add spacers accordingly until correct plunge is achieved . Although worth stripping down the CV's, cleaning and repacking them with fresh grease.
    Dave
    Dave France - The talent behind Fearless Motorsport Developments (FMD), creator of many a feature car including Brett Warburton's NovaWRC TotalVX cover car - a test run for my own project !!
  7. #4617
    23,816
    Ah, great info! As i've been wondering how much move ment there should be. So back on the ground with the wheel on? Then check? Same with the steering turned to check that...
    Inner joint is new and newly filled with grease, out is only about a year old, but i'll check and re fill with grease if needed.
    Cheers for the help Dave.
  8. #4618
    Dec 2003
    18,397
    Nasty **** dude, glad it's not just me who brakes things while fixing other things..
  9. #4619
    23,816
    I think it's always the way...
  10. #4620
    Mar 2003
    Manchester
    1,289
    Driveshaft plunge should be measured on full droop and compression
    Front end jacked up, wheels off - ideally suspension spring off strut so you can get full drop and compression and then take your measurement at the extremes of suspension travel
    Anywhere between 15mm and 18mm is a ideal figure
    Dave
