What's the job doing?
did you take some little cakes as a clincher???![]()
They sub for Thames water, if they get a leak or blockage we'd go in, drop a pipe before the block/leak, drop a pipe after the block/leak, thus bypassing the problem until they fix it.
the overtime will be extrordinary then, as every time i've seen water board people busy working, its after 4:30pm, when the overtime starts![]()
I worked it to be 48.5k including doing an extra night, (its 4 on 4 off) plus a couple hours guaranteed per shift. Add that to the fact I'm not paying rent, is only 5 minutes down the road, and that we already have a 10k head start thanks to ppi, I think we will be buying our own place very shortly... Or throttle bodies![]()
What did you do during the interviewspit or swallow
or both![]()
Gargled, spat into the air, caught and swallowed.![]()
No hose pipe ban in that room then
