Page 8 of 11 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 101
Thread: The Mk 1 E16 Twin Weber Build
  1. #71
    May 2008
    Cambridge
    198
    Next job was to weld up the seams. not had much experience with welding so I got as much advice from youtube as I could. pretty pleased with the results and got full penetration so even if its not pretty it will at least offer some strength.
    Steering rack painted
    Lower arms in hammerite
  2. #72
    2,618
    You've a good welding action, keep it up
  3. #73
    May 2008
    Cambridge
    198
    **Update**
    Fully Seam welded the inner arches and then sprayed with gravitex
    A few coats of primer and seam sealer all round.
    Then the top coat went on and looks sweet! Happy with the finish considering its a home job
    Stuck the engine in at night (as you do)
  4. #74
    May 2008
    Cambridge
    198
    Oil cooler and rad bolted in
    Then tidied up the loom with braided sieving.
    All starting to come together now
  5. #75
    Jan 2011
    HUN
    442
    Very nice work!
  6. #76
    23,816
    Bay looks fantastic, but didn't you not paint the bay?
  7. #77
    May 2008
    Cambridge
    198
    Sorry put the pics up in a rush and didn't label them very well. The bay was fully painted in Glacier white. looks a treat now!
  8. #78
    May 2008
    Cambridge
    198
    Seat bars welded in. Decided to just trim the original seat fixings as they can be a tad tricky to remove without butchering the shell
    Removed the bumper irons from the bumper and fitted quick release pins. (A few kg's saved)
    Engine is all wired in and almost good to go!
    Welded in some plates for the cage
    1st coat of primer
    Started to rain so I used the time to modify the steering column so it sits a tad lower.
  9. #79
    Senior User NOV4_SPORT's Avatar
    Dec 2005
    in front of the computer.
    3,033
    Really liking this build mate, the engine is amazing keep up the good work
    Iain
  10. #80
    May 2008
    Cambridge
    198
    **update**
    So treated the interior to a bit of paint
    Modified bracket in place
    Seats going in
    Driving position is spot on
    Harnesses bolted on
    Underside all cleaned up
    Rear beam good to go
    Fuel and brake lines in
    Also the engine now starts, Tricky to get going at the moment as everything is so tight (dont think i gave the bearings enough clearance) Starts with the help of a second battery tho, hoping to get some miles on it soon and start wearing it in!
Tags for this Thread
