Page 446 of 569 FirstFirst ... 346396436444445446447448456496546 ... LastLast
Results 4,451 to 4,460 of 5684
Thread: Benn's on going build
  1. #4451
    Apr 2007
    Old Radnor, Powys
    2,803
    who you having to re-con the turbo benn?
  2. #4452
    23,815
    With Dan help to get the bottom pulley bolt off. Got all the belt cover off, belt off and then started stripping it down...
    Puddle of oil...
    Ah i see a leak..
    Looks like both are leaking quite bad..
    Wet above the pump... So cant be the pump leaking. From what i can see on the seal it looks dry.
    This seal is dry too... Which i have been wondering if it was leaking..
    So gonna get two gen cam seals and a new bottom pulley bolt on order tomoz. Built it back up after cleaning it. Then see if that fixes it.
  3. #4453
    23,815
    Quote Originally Posted by brucer View Post
    James (countvauxalot) was gonna do it. But the one i've bought have been re built and hybrided already.
  4. #4454
    Sep 2008
    West Yorkshire lad
    22,243
    6 Post(s)
    1 Thread(s)
    I bet you get mighty peed off having to strip this down when it's looking soooo good, do you tend to buy genuine GM parts these days or not Benn?
  5. #4455
    23,815
    I have to, to make it right. It's simply not good enough.
    I hate the fact it's leaking. And i try to use GM parts or as close to them as poss.
  6. #4456
    Sep 2008
    West Yorkshire lad
    22,243
    6 Post(s)
    1 Thread(s)
    I think I got brainwashed with my old engine, I'd never bought anything but GM. I know theres good reproductions and probably the same companies that even supplied GM but I got paranoid if I went elsewhere incase the parts were faulty.
  7. #4457
    23,815
    Elring and Payne make most Gm seals. So i try and use them. But we stock FIA at work, so i use them too alot.
  8. #4458
    Sep 2008
    West Yorkshire lad
    22,243
    6 Post(s)
    1 Thread(s)
    So why the feck is this in bits then if it's FIA gubbins
    I jest btw, oh where's the next PS you needing doing anyway?
  9. #4459
    23,815
    I think the cam seals are Payne too.. But both are leaking... Who knows really.. And erm... Dont remember...
  10. #4460
    Senior User nova ian's Avatar
    Nottingham
    1,784
    I feel your pain on the oil leaks too dude
    Double check the rocker gasket in the corners over the cams, I had similar build up of oil in the same place as you and I did the cam seals and bottom pulley seal twice before finding it was actually the rocker cover!
    I'm in the process of doing the crank seal and end cap on the gearbox side to try and stop mine leaking, Also got a new seal for the oil cooler sandwich plate incase thats loosing some.
    Keep up the good work
