Page 54 of 65 FirstFirst ... 444525354555664 ... LastLast
Results 531 to 540 of 646
Thread: quaife straight cut box into the nova
  1. #531
    Senior User Club Member MARTIN KELSON's Avatar
    Oct 2004
    SHROPSHIRE
    1,604
    Dunno what you mean Chris.
    I've done a whopping 5 miles so far this year all under its own steam!!!
  2. #532
    Jun 2006
    Cheadle, stoke-on-trent.
    14,968
    Very Nice sir, good result
  3. #533
    Jul 2006
    Newport, Sout Wales
    1,403
    Great car this
  4. #534
    Mar 2006
    1,476
    well its now fully road legal!!
    i took it for mot and discovered the quaife box was not going to be any good as the ratios are just too close and not really letting the turbo build boost and pull hard through the gear, was just spending all the time changing gear!
    i could have changed the final drive to a higher ratio but as the quaife 1st is long ratio anyway it would have been like setting off in 2nd all the time if id have done that and the in gear ratios would have still been the same anyway.
    so i had a look through the vauxhall gearbox info that stuart has in his sig link and found that the f18 has similar in gear ratios and the same 5th ratio to the f28 but a different final drive and in 5spd and as i dont really want to change to a f28 i thought id get a f18, now the f28 has a 3.72 final drive ratio and thats the same as whats in a f20 4x4 gearbox and luckily i aquired a 3.72 cwp from a f20 4x4 gearbox a while back so i went and got a f18 from the scrappy off a cavalier and removed the cluster from it ready to strip all the gears off it and put them onto my 3.72 pinion shaft
    cluster out
    strip down
    its so much better now it has longer ratios
    got some new greenstuff pads put in too
    and went for a blast
  5. #535
    May 2004
    Nr Cambridge
    2,594
    Looking good Matt, what cwp did it have ?
    Is the old gear set for sale as I may know someone after one.
  6. #536
    13,605
    Nice work, stripping the gearset looks a scary task how do you know what you're doing (as Haynes has nothing about it)?
    Front looks a little high on that last pic or am I seeing things
  7. #537
    Mar 2006
    1,476
    Quote Originally Posted by Jonlem View Post
    hi, the quaife is built back up into a f18 casing and has a 3.94 cwp and std diff, its for sale if you do know someone for it?
    thanks
  8. #538
    Mar 2006
    1,476
    no your not seeing things iain it is slightly higher at the front but thats how i like it as i think it rides and handles better with a bit more travel tbh, gearbox work is all self taught, you dont learn unless you get stuck in
  9. #539
    Sep 2008
    West Yorkshire lad
    22,243
    6 Post(s)
    1 Thread(s)
    I sooooo need to see this car in the flesh/tin.
    I'd be interested to see your times down a quarter mile tbh though
  10. #540
    May 2004
    Nr Cambridge
    2,594
    Pm me a price Matthew, I know someone building a nice Xe and he currently has a f28 which I don't think is suitable.
