Can't argue with that then, I am quite sure others don't use 3" systems though but if they work so be it.
All that said there must be a big problem somewhere on it to of lost that much power
Is there a pic of your bay with filter etc in here somewhere? I've not seen one but I tend to be a bit erratic on here the last year, I'll trawl through if there is oneMain tell tale on your dyno printout is if the redline is a bit early, it's probably been calibrated a bit out.
Power = Torque x RPM, so if it thinks you're revving a bit slower than you are, the torque will be spot on, but it will calc your power a bit down on what it actually is.
Pics of filter sorry if there a bit crap ive just braved the garage to take them.
Also pics of the power graph sorry again if its a crap pic ill try and scan it if people dont get the idea
Also I must say a HUGE thanks to Dave at PEC (performance engine components) i phoned him and told him what id done over the weekend and he gave me a really good discount on another set of rods, its nice to see some companys will still help you when your luck is ****.
So these came in the post
I'm ringing him tomorrow with a made up story, discount ftwNice work cracking on with the repairs
Shouldn't have too much issue with your filter setup, used by plenty of people. It may well be pulling a lot of hot air straight off the exhaust though, that will definitely drop the power a surprising amount.
On the power graph, any idea where your usual redline is? it doesn't seem quite as much as 20-30% out though tbh.
