Page 98 of 105 FirstFirst ... 488896979899100 ... LastLast
Results 971 to 980 of 1050
Thread: My XE nova on throttle bodies (Project 275+bhp)
  1. #971
    Contributer Club Contributer david dixon's Avatar
    May 2004
    2,758
    is that 3" exhaust not setting you back a bit?
    Team Griffin Nova 2.8 v6, 10.9@124mph santa pod 2012,
    UK's Quickest N/A Nitrous FWD
  2. #972
    May 2004
    Nr Cambridge
    2,594
    Quote Originally Posted by david dixon View Post
    If its 3" its too big. Something has clearly gone wrong since the dyno as even if the figures were slightly out ( which I doubt ) its lost nearly 60hp hasn't it ?
  3. #973
    Feb 2010
    durham
    1,529
    Quote Originally Posted by Jonlem View Post
    Not according to SBD but I'll ask the question
  4. #974
    Jun 2011
    909
    Quote Originally Posted by Gareth_C View Post
    The fastest I got was a 13.5 but I was told I was wheel spinning quite alot.
    i saw it spin up 1st, 2nd and quite a bit of 3rd on that run. such a shame after whats gone into this bud... keep at it. get what needs fixed done first. sort out the oil lines and worry about the rest later.
  5. #975
    2,618
    I really don't want to sound rude, but did you run all the new engine components in before even taking it on the rollers? Kid gloves, variable loads & speeds for the first 1000 miles then fresh oil & filter is in order, along with limited revs is best.
    What was the oil pressure doing since the build? Where was the heat telling on the rods?
  6. #976
    May 2004
    Nr Cambridge
    2,594
    It shouldn't be spinning in 2nd let alone 3rd, even more so as your on a tall 1st and 2nd ?
    How did you set the arms up in the end ?
  7. #977
    Feb 2010
    durham
    1,529
    The engine was built and ran in on an engine bed in Essex somewhere by steveboyslim mate, the oil pressure was at 75psi and I haven't had the full rods out but the heat Mark were on the caps.
  8. #978
    Feb 2010
    durham
    1,529
    It felt like it was spinning in those gears others have said the same, the arms I haven't really played with Specky the wheels want moving back a few cm
  9. #979
    May 2004
    Nr Cambridge
    2,594
    It was run on a bench dyno at Joe Stevens prior to being fitted in the car, this is why I think something has gone tits up as it made something like 260hp there then 197 @ RS Tuning, knowing who mapped it initially I would be very surprised if the map was a issue and even if it was to lose over 60hp from a atmo engine is outrageous
  10. #980
    May 2004
    Nr Cambridge
    2,594
    As you say it was all very last minute for you but you certainly want to set those up for the next time out. On 2 of the runs I saw I'd say it wasn't wheel spinning after 1st as the gearing really does seems very tall, it wants a different cwp in there if your just using the one straight out of a F20
