Looking good, few minor things i spotted. Fr number plate screw heads need to be black not white?
Are you using the doorbars?
Im looking for an autograss nova,is this for sale??
Great car mate well done,attention to detail is spot on,really well done!!!
Just been in the garage for 10mins, sorted all the fails but the seat belt bracket
Maybe my usual paranoia but the coolent looks a little brownmaybe just rusty water ways ?
And there is too much travel on the brake pedal even with engine running
Adjust the self adjustment stuff manually on the rear brakes ? Or the bolt on the pedal?
Could bleed the brakes for the 3rd time
Didn't think the pics came out that well tbh, I will get some better ones soon
Thanks for the comments everyone
There is adjustment on the pedal linkage but careful not to over do it as they can bind.
Run the engine in then drop the coolant and change it when you do the oil.
What seatbelt bracket needs sorting?
Looking swish Edd, much more cosmetic bits to do on the outside?
Not 100% sold on the wheels, maybe a slightly lower stance would help them suit IMO?
Looking good!![]()
The bit that bolts too the seat subframe that your clip the belt into, I didn't bother fitting one![]()
Good idea on the coolent
Tbh I have never ever had too adjust the pedal, I will have a look
Cheers, yep I think it might need too be a little bit lower, I will seen once it all settles down
Cheers John
Few more pics
Me likes this one
Well done , will look even better with the decals. It's a credit to you for doing it slightly different to the norm without anything looking out of place.
