Page 202 of 327 FirstFirst ... 102152192200201202203204212252302 ... LastLast
Results 2,011 to 2,020 of 3267
  1. #2011
    Senior User Lewis.'s Avatar
    Jan 2010
    Heckington, Lincs. Drives: 3.1 Trooper & XE'd Nova SR Garage Ornament
    2,821
    at least it's better than some of my previous updates, which have simply been to announce that I've done nothing
    I can't work out the relative positions of your sump/manifold/gearbox though. has the sump been modified, or am I up too late?
  2. #2012
    Jun 2002
    Poole, Dorset, United Kingdom
    8,493
    Quote Originally Posted by Lewis. View Post
    Yes, the sump has been extensively modified.
  3. #2013
    Jun 2002
    8,493
    Thanks goodness the engine has today been fired up for the first time since the paintwork and other rebuilding.
    It needed a bit of detective work by someone cleverer than me, as I couldn't get it to spark........turns out one of the pins in the connector for the crank sensor was not pushed fully home, so I only have myself to blame.
    There's now an arm-long list of jobs to be ticked off before the first race on 21st April.
  4. #2014
    May 2004
    Nr Cambridge
    2,594
    Good to hear its running again
    As a precaution I'd check all the connectors if you have had a pin drop out, you certainly wouldn't want it to drop a injector on full boost
  5. #2015
    Jun 2002
    8,493
    Quote Originally Posted by Jonlem View Post
    I will check them all, but the crank sensor connector was the only one which had to be dismantled - as it passes through a tiny hole in the bulkhead, the plug had to be removed.
    So at least I know it was not put back together properly (by me).
  6. #2016
    Jun 2002
    8,493
    The Nova took a test run on Saturday afternoon, with no doors, no wings, no bonnet, no tailgate and no windscreen. Quite breezy.
    The clutch has been giving us major headaches, and still isn't quite right, it looks like long term the master and/or slave cylinder will need to be changed. But hopefully it will be OK for the racing this weekend.
    A few photos of it sat in my friends' workshop;
    I would never have got it to this stage without his help, that's for sure. We've now spent 4 days pretty much non-stop on it.
    Suspension geometry is now all set-up, the doors have now been primed, and will be top coated tomorrow. So I now have to bolt on all the bodywork (not a big job on this!).
    I'll fit this rather natty new 'catch tank' tomorrow;
    And then I need to make some panels to fill the rather gaping hole in the boot;
    Other jobs to be ticked off are;
    Getting the tyres filled with nitrogen (now available at our local tyre depot)
    A bit of tidying for the wiring
    Sealing up various holes in the bulkhead/floorpan
    Bleeding the cooling system
    Fitting the battery properly (I had to send the race battery back due to charging problems, and it's coming back to me tomorrow)
    Machine polishing the paintwork
    And a bunch of other little jobs, so more late nights.....
  7. #2017
    Senior User mowgli's Avatar
    35,194
    colin, if there is no rule on what you need to make it out of, could i suggest using that corrugated plastic stuff they use on cheap coldframes & sell at b&q, correx it think its called... it weighs about a 1/4 of feck all...
  8. #2018
    Jul 2002
    8,107
    Mental Nova!
  9. #2019
    Jun 2002
    8,493
    I'm not familiar with that material, I was going to make it out of carbon fibre, but as I'm in a rush and don't really have time to make a lot of templates, your cheap and cheerful suggestion might be the one for me (no rules on what the infill panels are made of, so far as I am aware).
  10. #2020
    Senior User Mike's Avatar
    26,594
    Crack on, looking the part now Colin!
    Giving me some real good ideas/inspiration of something Im planning on building at some point.
