Page 98 of 111 FirstFirst ... 488896979899100108 ... LastLast
Results 971 to 980 of 1109
Thread: Project: Gold Snowplough Turbo
  1. #971
    23,816
    So you stripped the box just to check it? Or was there signs it had been apart? Should of said i have 3 spares..
  2. #972
    Aug 2007
    The Hague, NL
    1,114
    UPDATE Wanna stick el-cheapo diff oil in first, do a few miles and drain it out in order to stick some quality stuff in.
    Tek, why would you want to run cheap oil first? To sort of clean out the box? Or is there another reason? Please spill the beans...
    Any idea what quality oil you are going to run in her?
    Cheers,
    Niek
  3. #973
    Senior User maddogdaz666's Avatar
    Jan 2010
    West Yorkshire
    3,042
    The info on xe cams is in issue 76 autumn 2007 on page 124 and it says a 20 bhp benefit on the inlet xe cam retarded half a tooth, on an already healthy cab turbo. It's a really interesting read
  4. #974
    23,816
    It's on their website too Daz.
  5. #975
    Jan 2010
    West Yorkshire
    3,042
    Lol I've never been on it, I'm still Old skool, I'm not used to all this interweb thingy yet
  6. #976
    23,816
    i only found it when i needed the info as i was setting mine up..
  7. #977
    Jul 2002
    8,110
    I opened it up to check there was no damage to anything else as I found the diff with the corner of two of it's teeth chipped and a small hole where something looked like it exited with some force. So just to be on the safe side. However I can't seem to find out what final drive it has. I'm hoping it's a long ratio so I get a calm motorway driving experience
    Quote Originally Posted by nova_niek View Post
    Cheers,
    Niek
    Yeah, to clean it out. No doubt after opening, as well as it sitting for a while with tissue/cloth in the shaft opening, there will be a bit of dust and what not in there as well as old oil. Wanna run it for like a few miles druing run in and then flush it and put good quality oil. I've had my eye on castrol SynTrans (I forget what it's called excatly) 75/90 fully synthetic. Should get it for a good price from Halfords with the trade card.
    Quote Originally Posted by maddogdaz666 View Post
    Well it'll be a healthy LET, it'll be fully rebuilt so 20 brake will be nice.
  8. #978
    Jul 2002
    8,110
    UPDATE
    Lousy weather and work meant no progress this week. I'd much rather have it hammer down with rain all day or be sunny rather than a mixture of both every couple of hours... weather like this just drives me nuts!
    I did however get the following bits...
    Mate of mine has been pestering me for the standard Cav/Cally IC I got. Because of that I decided to look around for a FMIC. After much surfing and deliberation I decided to go for this one
    It seemed to tick the boxes. Dimensions are 680mm x 140mm x 65mm 2.25" inlet/outlets easily reduced with a couple reducer hoses to 2". And it didn't break the bank.
    I also got this
    Got it from Christian1992 on here. Hard to come by so will deffo be useful in the future should anything go wrong with my current ones. I did have a faulty fuel gauge anyway. I took out all the gauges, cleaned up the housing, cleaned up the dial faces, fitted them back together with the new fuel gauge and also re-coloured the red zones on the dial faces too. I had to seeing as they had all faded to a light orange
    Hoping the weather becomes better over the coming week or so. Contemplating if I should take some of my paid leave to speed up the progress (I've got sh*t loads left).
  9. #979
    Dec 2003
    18,397
    Do you plan to mount the IC behind the grill part of the bumper? is that the size to get for doing so?
    Jul 2002
    8,110
    Yeah, rather than mount it down by the cross member I'm looking to mount it up instead due to restricted airflow by the plow. I measured the opening and this looks like it'll allow just enough room for the hoses. I measured the gap as approx 800mm on the Nova. I'll be able to tell next week when I remove the bumper.
