Page 107 of 146 FirstFirst ... 75797105106107108109117 ... LastLast
Results 1,061 to 1,070 of 1455
Thread: Dan's L reg Td SX
  1. #1061
    Jun 2009
    Newark
    4,682
    Well I got back from work today at 5.51 and guess what,... I did more work on my car... IN THE SUN
    I made the wing and the door fit the sill better with the aid of a block and a hammer. Then I preped the wing with 400wet and dry, panel wiped it and sprayed it with grey primer.
    What do you think. I think it fits miles better than most original Novas wings do!
    Overall I am very pleased with it and plan to do the other side tomorrow.. Good times
  2. #1062
    Dec 2003
    18,397
    That is a good gap dude, good going!
  3. #1063
    Jun 2009
    Newark
    4,682
    Cheers Scott. the door used to stick out nearly 10mm past the door and the wing stuck out a good few mm past the door so overall pretty tidy now
  4. #1064
    User Club Member Dervy's Avatar
    May 2010
    1,064
    that wing looks spot on mate, primer looks really goos to.
  5. #1065
    Jun 2009
    Newark
    4,682
    Cheers Sam
  6. #1066
    Senior User Lewis.'s Avatar
    Jan 2010
    Heckington, Lincs. Drives: 3.1 Trooper & XE'd Nova SR Garage Ornament
    2,821
    looks good, jealous of your solid battery tray I did laugh when you were pointing out those microscopic flaws in the wing though
    Problem is, it's not a proper Nova now, you should be able to see the panel gaps from space
  7. #1067
    Jun 2009
    Newark
    4,682
    Quote Originally Posted by Lewis. View Post
    only bit of the car that is solid!
  8. #1068
    Jun 2009
    Newark
    4,682
    Well I was ashamed at the lack of effort I have put in recently after seeing Craigs GTE project so I thought I best get my **** in the garage and finally get the wheel Lacquered.
    I used 2k Lacquer as I wanted a deep shine,
    Here is the results. Not perfect but pretty good I think
    I have also stripped the long Shaft and found out why it was knocking,
    Cleaned up the Tapered shaft.
    And the Big block inner.
    And here centre of the outer, Looks to be the part at fault!
    I have sourced a New outer off Lewis so all is good.
    While the Wheels were drying I gave the outer a coat of primer. I will be doing them silver and the shafts black enamal like the rest of the steering/suspension components
    Any way that is all for tonight.
  9. #1069
    Jan 2010
    2,821
    Wheels look mega.
    Wasn't aware I gave you an inner joint thought you wanted an outer? and i've not given you that yet
  10. #1070
    Jun 2009
    Newark
    4,682
    Wheels look mega.
    Corrected, and you will though!!
