its ran in the most awkward way!!! ive got it runnign through this capping on the firewall
right behind that capping is the brake pedal gubbings, it is the worst place imaginable to get it to fit (especially when you got to squeeze inside between the cage and the seat to get in the footwell) but its effective.
those gauages are similar.
cheers buddy
ebay, type in m14 x 1.5 to 1/8 and it will bring them up. only problem is, is that the 1/8th sensor has a long protruding end (like a coolant sensor) so it cant be screwed in that far to seal. ive used ptfe tape and hope it doesnt leak. the other option is to have one that screws directly into the end but then you cant have additional items like the pressure sensor, unless you use the other oil gallery above the pressure senders standard place.
thanks, inspiration from numerous other WIP threads help with choices of colours.
