What's the best way to fit one to a mk1 dash? Wiring is done just need it to sit in there
Just a case of sitting it were you are happy and then chop and fit the dash back till it fits bit of a ballake to do mask the inside of the clock area and you can scribe the click face to the dash easyer if you got someone to hold dash for you and some brackets to hold the clocks in place
hammer!
Crowbar & rachetstraps
Get yourself a knackered dash to test out on first.
If you've not got one buy a dremmel and start cutting away small bits until your happy with the fit.
Cut it up the other day, gonna make a coustom shroud for it now
I bonded and used filler with a cut down mk2 astra instrument surround - gave more flexibility where I choose to cut the nova mk1 dash. However you'll then need to paint or flock to tidy it up then.
"let me drive.. i won't make a fool out of you"
