NA novas are like getting a blow job off the wife, 400 bhp let novas are like getting one from her younger sister
Single plate was not reccomended by AP's technical department, but a twin plate was.
The input shaft would only be short by 4mm or less, possibly only 2mm if Gareth removes more metal from the gearbox casing (merris style)
AP said it will be ok as each plate has to deal with 100ish ft/lbs of torque.
One of AP's hydraulic round face 54mm slave cylinder and thrust bearing will sort the operation of the clutch.
Steve
ha ha
if you send your gearbox down here, i will get merris to shave the 2mm off with his axe?
