Results 1 to 8 of 8
Thread: Weber 32/34 DMTL Manual
    May 2004
    London/Reading University
    720
    Default Weber 32/34 DMTL Manual
    I am having troubles with install. I dont have manual for weber and I have no idea where the basic mixture adjustment screw etc etc...
    If someone has a manual scanned or in any other format can they please send it to me via email please...
    Will be appreciated soooo much!
    supernovagt@gmail.com
    Thanks a lot!!
    Mar 2003
    HMP Dartmoor Hobbies: Running up walls Dislikes: Bling
    2,886
    mixture screw is at the back near the base of the carb inside a small tube shaped housing.
    Club Member ade's Avatar
    Mar 2002
    Glasgow Wears:A Skirt
    10,822
    try contacting www.webcon.co.uk
    Theyre the weber people in the UK.
    I contacted them when I had probs with my weber 32/34 and they emailed me a scan of the fitting instructions.
    VVV helpful.
    Also- for best results take it to a weber specialist to set it up right. I had big probs with mine but discovered its coz of a warped inlet manifold the carb bolts onto - was sucking in air causing huge drop in power...
    Ade.
    Member
    Apr 2002
    Ely, Cambs
    266
    check your email mate, i just sent you the manual as jpeg files 8)
    Senior Member
    Jan 2004
    299
    can you send it to me too ??
    May 2004
    720
    What exectly and where do you want me to send it to?
    Nov 2003
    Austin, Tx, Usa
    24,199
    right, just got mine
    and bloody hell i dont get any of it ::
    i know the fuel in goes into the pipe with 'B' on it
    choke to 'H'
    throttle to 'D'
    thats all i know :?
    any help
    what goes onto 'K' 'F' and 'E' :|
    Mar 2003
    2,886
    the vacuum advance goes into the one at the back mate.
    The front one has a cap on it to seal it off cause its for something you havn't got.
    Fuel Pump -------^T-piece with return on^-----------carburettor
    It should tell you exactly where everything goes on the manual anyway mate.
