Page 1 of 13 12311 ... LastLast
Results 1 to 10 of 130
Thread: Project Jeremy
    User Club Member
    Aug 2005
    next to the speakers
    1,318
    Default Project Jeremy
    Well here goes..
    Base Model a few weeks after i got it:
    Genuine miles.
    Until just before christmas I when bought I bought a set of cav GSI rims (cheers ernie ) had them refurbed and sprayed and got rid of the lovely sidestrips:
    I was working as a tyre fitter before christmas and unfortantly i dropped my keys in a customers car and the *******s never came back. With it being a nova I only had one key. Silly me didnt check here to know that there is a code on the bottom of the ignition barrel thier. So i wired in a hidden switch, key, and push start, all maplins specials.
    My dodgey wiring caused the interior and engine bay fan not to work, resulting in a very unreliable ride. So over christmas whilst having to drive my sisters superfly ka i decided its time to get this out my mates garden and put it to use:
    As you can see from the sunshine, I bought the calibra donor car in the summer, my mate stripped it of its xe and weighed in the calibra. The engine has sat in his garden since...
    Over christmas I landed a new job at a local parts place (allparts - http://www.allparts-automotive.co.uk) perfect! So began buying some tools and booked the 2nd week off in January. I had never had the guts to do this and had always planned to pay someone to do this for me. But after alot of research on this forums I thought "I can do that" and so:
    and its out... (if it was only it was as quick and easy as writing this post)
    But on a serious note, i dont have alot of tools (breaker bar, hammer, sockets 10-20 and a 30, spanner set, screwdrivers and two trolley jacks) and I managed quite easy. With some help from some friends of course!
    Next step: strip out the sound deadening and nitromorez the areas i need to weld. Tommorow or Saturday - keep you all posted.
    Taking an Engine out Guide (for those that dont know how to do it, like me up until a couple of hours ago)
    Disconnect everything from the engine cable and pipe wise, always good to start with battery (label it if you want)
    Radiator out, manifold out, hubs off (I disconnected everything and pulled the hub/driveshaft out from the gearbox as one piece, on both sides)
    Take off the anti-roll bar, lower arms and the funky sway bar things on each side.
    Disconnect the gearbox linkage by taking out the 'T' style pin, (you'll know what i mean when you see it) undo the bolt that pinches in the arm, get in the car n give the gearstick a wiggle.
    Make sure everything is as clear as possible in the engine bay, wires, pipes etc.
    Take the weight of the engine with two trolley jacks, one under the gearbox and one under the sump, on the flat bit on the left, use a square of wood. (not recommended: jacking on the sump, however mine was fine)
    Undo gearbox mount first (right at the back, under the inlet right at the bottom, tackle it from drivers side front wheelarch) then the left hand side mount and finally the right. Obviously becareful with the last mount as the engine could tip, however mine didnt.
    Slowly lower the engine onto three bricks (works well) you might have to lift the front of the car (two man job) and adjust it so the engine is NOT supported in anyway by the car.
    Get a couple of mates to either:
    Lift the front the car up and roll the car back over the engine or as I did (check the last picture) lift the front end of the car to one side. Leaving the engine on the deck.
    When its out you can pick it up with a couple of mates. Hope this helps
    Apr 2006
    14,188
    I quite like that colour, was this not on ebay a week ago...?
    User Club Member
    Aug 2005
    1,318
    nah, i bought it over a year back from some guy near dover. He ran a BMW dealership and traded it in belive it or not?! It was standard when i bought it.
    Jul 2003
    United Kingdom
    11,736
    good work , thats just how i did my first engine swap , but after a few of them , i went and got a proper crane etc, makes life so much easyier
    User Club Member
    Aug 2005
    1,318
    Thanks mate. When i move into a place with a garage i will probobly get a hoist. Picking up the engine on Saturday, gotta try and squeeze it into the back of the sisters ka, whats the chances? slim?
    Moderator burgo's Avatar
    Apr 2003
    kettering
    22,773
    11 Post(s)
    na it will fit . good to see you doing what you said you were gonna bud
    Flashbang Is stil GAY
    Oct 2005
    Scun-thorpe
    6,064
    when i got one of my xe's from Rexy it only just when in the backo fmy uncles veccy
    3 1/2 rods.
    Feb 2004
    Lancaster Drives : 1.6 8v T40
    5,975
    Not much use, but an E16SE definetly fits in a royal mail van !
    Apr 2003
    kettering
    22,773
    11 Post(s)
    i got a v6 in the back of this easy enough so a valver will go in a ka
    Senior User Club Member
    swindon
    7,906
    good work fella and thanks for the thumbs up for the wheels.
    On the subject of engine's i hade 2 xe's in the boot of my 2.2 diesal civic and a gearbox to 1 side in the back seat area.
    I also had chris gsi sat in the front and jen sat in the back.
    It drove fine but scraped a few of the speed bumps going out of london.
    Oh the joy of a lease car.
