Results 1 to 7 of 7
Thread: Engine swap
    Apr 2006
    Lowestoft
    881
    Default Engine swap
    Thinking about swapping my engine, theres nothing wrong with the one thats in there but i just want summat with a bit more poke!
    It currently has a 1600sv engine from a cav in there and i was thinking about maybe a 1.4sr lump or maybe a gsi lump.
    Question is, how hard is it to change an engine?
    what do i need to do to change from carb to injection setup?
    will i notice much difference?
    I need summat that is reliable, good acceleration and not too bad top end.
    All help much appreaciated!
    Dec 2006
    181
    Post
    If your engine is o.k why not try an uprated cam and bigger carb???
    Apr 2006
    Lowestoft
    881
    Because i just fancy summat a bit different, either a tuned small block or an injection engine, just wanted to know the difference it would make really!
    Jun 2005
    Ilkeston
    13,425
    the 1.6 you have is a small block ??
    Dec 2006
    181
    Post
    Not worth the bother,stick with what you've got mate,spend the time and money improving that,like i said before^^ decent cam,better carb
    chippy shoulder Admin
    Nov 1999
    Crowland, The Dirty North
    35,414
    18 Post(s)
    fittinng the mpi 1.6 8v from a gte/gsi will instantely give you (nearly) 100bhp... the 16SV is a really really awfull engine compared to the mpi, so its not work camming etc..
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    1.4Sr engine is a downgrade... Less power.
    Get hold of a gte/gsi head, inlet, loom etc from a e16se engine.
    Fit that if you want injection. You'd need tank, pump etc too tho.
    Or fit a 16se head and t40s....
