Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Thread: Opening an ISO file
    Senior User Ben's Avatar
    May 2002
    New Zealand
    9,554
    Default Opening an ISO file
    Just downloaded Autodata 2006 Cracked version, trying to open it and it asks what program created it, file says its an ISO file so how can i open this?
    Bzzzzz Admin Jack's Avatar
    Apr 2003
    Hicksville, GL
    44,173
    4 Post(s)
    ISO are CD Images I think. You'll need to use Nero or Easy CD Creator etc to open it with, and burn to a CD to read the contents, or a CD drive emulator like Daemon.
    [edit]ISO file type
    May 2002
    New Zealand
    9,554
    I got what you said until you put the link on there now confused to **** LMAO
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    Any CD recording program can/should be able use it.
    Just open cd burning program.
    Click something like File>Open.
    Then find the .ISO file
    And you should then beable burn it.
    Then you can run/install the program from the disc you made.
    May 2005
    Bristol
    1,536
    Or you can use this to open it without burning the images. It's a usefull and free little tool.
    Moderator Mazz's Avatar
    Jun 2005
    Stafford.........Drives : Audi A4 + NOS Nova GT'XE
    6,657
    1 Post(s)
    http://www.isobuster.com/ will open to ISO file so you can then extract it etc etc...
    But most decent burning programs will burn it, Nero (www.Nero.com / www.ahead.de) definately does.
    Burn as Long live the Nova said..
    May 2002
    New Zealand
    9,554
    Arrrrrrrrrrrrrrrrrrrgggggggggggggggggggggggghhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    Its quite simple.
    Download ISO buster, or the program Bump suggested.
    Open the program, use it to open the ISO file, then copy/paste the files onto your desktop/folder.
    May 2002
    New Zealand
    9,554
    ok i will try. Rather rebuild an engine!
    Its the tits!
    Jan 2005
    pompey
    1,851
    all you have to do is down load alcohol 120% and that will do all the work for you. simple! goto http://trial.alcohol-soft.com/en/ and get the trial
