Just spent another two hours doing a good job of lapping the valves in. Surprisingly they were in pretty good condition to start with, leading me to think that this head has maybe had some work done before. I only had to use fine grinding paste to obtain a 3mm band of clean material on every valve and seat, so hopefully this will ensure no leaking valves unlike the head I put on in december. Forgot to charge the camera battries again so no pics still, I'll have to leave a note next to the head for when I get the new gasket set, as i haven't put the valves back in due to not having any new stem seals spare.
I think I may have a pin-hole leak in the thermostat housing where the top hose sits, Think I might have to drill it out and get some chemical metal on it, or I might just see if it leaks when it's all back together!
Really all thats left to do is fit the stem seals and put the valves back in, then make sure I've got the right gaskets and the attack will commence!!
I was thinking of cleaning up and painting the spare cam carrier this week, But I'm not sure if I should be swapping a freshly run-in cam into a carrier that had a very worn cam in it? Any advice on this would be welcome.
), and she'll be up and running again.
