how much should i lower my nova when rolling on 15"
dependin on the offset of the rims,hopefully being somewhere near et49 and low profile tyres then you shouldn't have much trouble droppin it 60mm
40 or 60mm
depending which 15s you have :wink:
Old XE track car
or go 80-100 on coilovers :wink: ::
would it be ok lowered 40mm on 16's with a novadose kit?
as long as the offset is correct (ie the wheels don't stick out from the sides of the car then it'll be no problem at all and kit won't make any difference
Kit shouldn't make a difference, but the tyre size and wheel dimensions (offset/width) will. 40mm on 16s you'll probably need to roll the arches.Originally Posted by Gistra-Nova
"It'll be done when its done"
you'll definetly need to roll the arches. i'm on 16s and dropped 60mm no scrubbin though, the offsets 45.
if it was me ide lower it 60 mm m8 n then it will look the dogs
