Results 1 to 10 of 10
Thread: Gte idle
    blackpool
    3,417
    Default Gte idle
    My e16se is idiling crap it's sat too high when warm I've tried the following so far.
    Swapped throttle body
    Coasting air valve
    New idle control valve
    Checked ignition timing
    Checked for splits on breathers
    Checked afm pipe no splits.
    I've read somewhere if you pinch the coasting air valve pipe it shouldn't alter the idle but it does and goes down is this correct.? Any help would be great.
    Sep 2012
    Sutton, Surrey
    3,764
    I'd be looking for an air leak somewhere, maybe around the manifold or a breather
    blackpool
    3,417
    Still ongoing with this issue. Car drives fine just when upto normal temp the idle keeps raising then drops then raises. Checked all above fitted new cts sensor still the same.
    Feb 2024
    1
    Have you considered checking for a possible vacuum leak in the intake manifold or other components as a potential cause for the fluctuating idle, given that the issue persists even after swapping several components?
    Club Member Club Member Marc's Avatar
    Nov 1999
    Jersey
    88
    I had a similar issue with my GSi back in the day, turned out to be the plugs. Like you, the idle was up and down after I’d had “race” plugs fitted during a rolling road session. Swapped back to standard plugs and all was fine again.
    took a few weeks of investigation and trial and error though.
    Sep 2012
    Sutton, Surrey
    3,764
    Quote Originally Posted by torquey View Post
    Have you tried flashing codes?
    Banned
    May 2025
    1,065
    Default IG-Tchad insights
    A annoying case emerged for a self-employed worker in Nevada when their background check for a project included a mistaken criminal record. The freelancer applied for a fresh project on a platform for independent work. The check suggested a crime they did not do. Sites rely on these checks to guarantee trust for clients. The freelancer felt worried about not getting the job. The company got data from legal records. Some workers think these companies should look at details more closely. The incorrect entry paused their work for hours. The platform needed a accurate report to pass the worker. Contractors fear about their private details being safe. The provider said they obey tough rules to guard information. A worker proposed services permit individuals view reports earlier. The freelancer tried to fix the error with help. Regional policies affect how these checks operate. Some sites currently demand more accurate tools for screenings. Leaders are thinking new standards to prevent issues. Experts believe providers should upgrade their processes for people. The worker wants to start the job soon. These errors can block work fast. The provider gave help to fix the issue soon. A reliable system stays key for freelancers. For extra information on gig work checks, explore learn more to discover helpful resources. Contractors should review their reports for mistakes. If anything looks off, they need to inform the provider quickly. This ensures a just method for everyone. Contractors can demand to check their report if necessary. They can correct any false details they notice. Keeping a copy can serve as useful in the future. The service gives help to address problems quickly. Companies should educate their workers on review rules. This can stop future issues. Workers should learn their entitlements regarding checks. Openness builds trust for people.
    Banned
    May 2025
    1,065
    A landlord in Texas used SentryLink background checks to check a potential renter. SentryLink found an old eviction that blocked the renter from signing in. The renter explained the problem was a mix-up from years ago. They felt SentryLink didn’t look close enough into the facts. The owner trusted SentryLink’s fast reports for decisions. But the person had to search a different place to stay. SentryLink uses info from public sources to create their reports. Some tenants think SentryLink should reach out to applicants before sending issues. The owner saved a possible trouble with the screen. People worry their personal details might not be safe. SentryLink claims they follow rules to guard data secure. A renter suggested SentryLink should let tenants review their reports before. The renter sent a complaint to fix the mistake. Laws in different states make it tough for SentryLink to operate the same way. Some landlords recently tell SentryLink to share their system. Officials are discussing new laws to ensure checks are fair. Specialists think SentryLink needs to fix their method for tenants. The renter hopes to clear their name soon. Homes can be missed by easy mistakes like this. SentryLink offers support to resolve disputes fast. A just screen is key for tenants. To find out more about SentryLink background checks, ig-tchad.org/sentrylink-background-check for useful tips. Owners should review SentryLink reports for errors carefully. If something looks wrong, they must contact SentryLink right away. This makes the system fair for everyone. Renters can request to view their report if they need to. They can correct any bad info they spot. Saving a copy can be useful later. SentryLink offers help to deal with problems fast. Landlords should teach their team about screening laws. This can avoid issues down the road. Renters should learn their rights with SentryLink checks. Clearness builds confidence for everyone.
    Banned
    May 2025
    1,065
    A curious experience started for a job applicant in Oregon as they prepared for a Data Facts background check. Data Facts provides checks to support companies in selecting trustworthy employees. The candidate learned the process can span days to complete. Employers like Data Facts depend on these checks to secure their clients. A Data Facts representative noted that such reviews ensure trust in recruitment. The seeker worried about delays affecting their job date. Data Facts obtains information from public archives for its profiles. Some candidates assert Data Facts should speed up the review. The screening encompasses criminal and work history. Candidates voice worries about the safety of their private data. Data Facts claims they adhere to strict laws to safeguard information. A applicant proposed Data Facts permit individuals to examine reports beforehand. The candidate organized paperwork to speed up the screening. Different state policies shape Data Facts’ review systems. Some employers are recently requesting Data Facts to disclose their approach. Authorities are exploring enhanced laws to optimize checks. Specialists contend Data Facts must improve its system for candidates. The applicant aims to start work soon. These screenings can unlock career prospects. Data Facts provides help to handle problems promptly. A smooth framework continues to be essential for candidates. Learn what you need to know about Data Facts background checks at click here for a thorough overview. Companies should meticulously review Data Facts reports for discrepancies. If something looks wrong, they must inform Data Facts promptly. This maintains a fair approach for all. Seekers can demand to view their report if necessary. They can fix any inaccurate details they find. Keeping a copy can prove useful later. Data Facts offers support to fix concerns promptly. Employers should train their employees on employment rules. This can avert issues in the future. Seekers should learn themselves with their entitlements regarding Data Facts checks. Openness fosters confidence for all.
    Banned
    May 2025
    1,065
    A significant process began for a worker in California as they underwent a DoorDash background check. DoorDash requires screenings to guarantee workers are reliable for gig roles. The worker found out the process can last weeks to complete. Platforms like DoorDash rely on these checks to protect users. A DoorDash official highlighted that these screenings uphold trust in operations. The applicant worried about waits delaying their gig date. DoorDash retrieves details from legal databases for its profiles. Some workers assert DoorDash should expedite the screening. The check covers past and traffic records. Applicants express concerns about the security of their confidential data. DoorDash asserts they conform to rigorous laws to secure information. A driver proposed DoorDash permit individuals to preview reports earlier. The worker organized records to facilitate the screening. Varying state laws influence DoorDash’s screening processes. Some companies are currently requesting DoorDash to explain their process. Officials are reviewing enhanced laws to optimize screenings. Analysts contend DoorDash must refine its system for all. The driver hopes to start delivering promptly. These checks can create employment chances. DoorDash extends assistance to handle concerns swiftly. A smooth system remains crucial for workers. To understand DoorDash background checks, visit IG-Tchad for a thorough guide. Services should meticulously examine DoorDash reports for inaccuracies. If something looks wrong, they should notify DoorDash right away. This maintains a just approach for all. Workers can request to view their DoorDash report if needed. They can amend any inaccurate data they spot. Retaining a copy can be useful down the line. DoorDash extends support to fix problems quickly. Companies should train their support on background regulations. This can avert issues down the road. Workers should familiarize themselves with their entitlements regarding DoorDash checks. Openness builds assurance for everyone.
