Did you put in a quaife diff or use the blackline
What sort of times you running now?
I cant realy say how quick its going at the moment pal i have been 7.644 in the 1/8 at pod with 200hp less than im running now but still only go 7.9-8.22 at Melbourne in the 1/8 but melbourne is a totally un prepared tarmac track with no glue or rubber down what so ever. Im looking forward to getting back to pod for doorslammers and usc just to see how much quicker it is in the 1/4 now and after the new cams and clutch are fitted. Mid 10s id suspect
New box all back together. I noticed inside this later f18w the have a latch to hold them in gear and stop it jumping out which is handy. Must have been a diesel thing?
Also got 2 new preasure sensors for fuel and oil for ecu cut.
Hall effect speed sensor to pick up off the rear hub / meaning i can run traction control and boost by gear.
4 puck paddle clutch to go with the cg motorsport cover.
New cam and pulleys.
Fittings for new bigger fuel tank.
And best of all i can eventually take advantage of my ecu having bluetooth. Which connects wireless to the tablet meaning i can run tunerstudio and have installed the lambo dash into shadow ms (rings go away when i start the car)
I hope all these added extras will give me the edge off the lights. Rather than all the power when its not wanted.
New fuel tank i have made up for it.
Current tank is 5ltrs and im only getting a run and back up the return road then having to refill this one works out to 14.4ltrs so should make life easier
Nicely done Sir!
Impressive skills on the tank
Tank skills!!!
Sensor mount made up and fitted just needs the trigger wheel now.
