Hello. Greetings from Slovakia.
I decided to put together my C16SE engine block and find some head to fit on it. Original ones are out of my budget so far, I am looking for something else.
Another reason for something else is that I have functional C16SEI in my car, I would prefer to keep similar/same loom, ignition distributor etc.
I´ve found extremely cheap head from C14NZ, head gasket looks the same as C16SE or SEI.
BUT there is one small difference, C14NZ has cylinder diameter 79,3mm, c16SE has 80,5mm, that means 1,2mm difference.
What do you think, will it fit? What about CR?
Thanks a lot.
Cheers
